Samsung UE46D7000 - panel or t-con?
    Hi
    I have a Samsung UE46D7000 (Panel: LTJ460HQ01-B, t-con: S240LABMB3V0.7) with the display problem exhibited in the attached photographs (both sides of t-con connected, and each side connected seperately - failure in left upper quadrant)
    It sounds like panel failures are common on this model, but I was hoping someone could confirm definitively whether this is panel or t-con?
    Thanks in advance.
    Re: Samsung UE46D7000 - panel or t-con?
    Looks like panel
    Tab bonds.. maybe workable fix
    If not bad panel.
      Bad panel.
        did you try cutoff method?
          Looks like panel...
            Bad panel...don't waste any more time on this set, sorry......
              Thanks, all.
              I haven't had any success with tab-bonds but a 46" is worth another try. It's the biggest panel I've had to deal with - it may not survive...
                be sure that over heat in Tcon (like AS15 )
                if there are 2 connexions to panel, eliminate 1 by 1 and see if problem persist
