Is this a bad T-Von?
+ More Options
Posts
  • Nikolai Tesla
    • Oct 2016
    • 28
    • Netherlands
    Got this Sony from a friend, a Sony KDL46-EX500, I think it's the tcon but I'm not sure.
    https://myalbum.com/album/ikLNYBvsI9aR
    Anyone with a good tcon and a remote please write me.
    Ps even with a Sony remote the red led doesn't blink . Is the remote board dead?
  • Hamie
    • Apr 2014
    • 1383
    Re: Is this a bad T-Von?
    I'd say mainboard.
    • Nikolai Tesla
      • Oct 2016
      • 28
      • Netherlands
      Why?
      • llonen
        • Sep 2014
        • 495
        • hampshire
        Well bad tcon boards don't usually produce horizontal lines, none the less you could try disconnecting one at a time left and right feeds from the tcon to panel and see what changes you get.
        • Nikolai Tesla
          • Oct 2016
          • 28
          • Netherlands
          Guys, I made some NEW photos..recheck my album please. On HDMI2 no horizontal lines. But maybe artifacts (I'm Dutch, not a native speaker).
          • chrismurphy
            • May 2014
            • 251
            • australia
            Bad T-con
            • koka0011
              • Apr 2013
              • 30
              • Sri Lanka
              check the main board.you need to check coil packs.try to replace them or use jumper.trace lvds connector you can find them.if you cannot see the coils clean the ribbon.
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                you may have a gamma issue, but i can't see the vgma test points on your t-con. there may be some on the panel driver board. your gamma chip is the maxim chip.
                WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help NeededπŸ™
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
                • thelankanguy
                  Sony KD-55X9000F TCON Issue
                  by thelankanguy
                  The TV shows a black screen with no image.
                  TCON ribbon connectors were disconnected individually for image and there was no half image even.
                  Later both ribbons were disconnected and TCON voltages were tested.
                  12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                  There is also a short to ground in this circled inductor.
                  Is this a TCON issue or something else ?...
                  12-13-2024, 12:27 AM
                • bbrain
                  Sony KD-55AG9 TCON?
                  by bbrain
                  I have this problem with my Sony 55' AG9.
                  It flashes 4x.
                  I have found the service manual, and seems it is the TCON.
                  Before I buy a TCON can someone check the vid?
                  Thanks in advance!...
                  09-19-2024, 10:50 AM
                • rimwall
                  Sony KD-65x8500b - bad Tcon or panel?
                  by rimwall
                  Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                  a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                  b) the Tcon board is malfunctioning,...
                  10-24-2023, 07:58 PM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
