LG 55LN5750-UH backlights
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    So I've gotten this LG 55LN5750-UH TV set in with bad backlights. Getting a strip replacement for this set is nearly impossible. I found those LED's at SJ: http://www.shopjimmy.com/replacement...-set-of-12.htm
    Problem is that those at SJ are for up to 50" TV, like a 50LN5750. I wonder if they are the same for the 55"? Cording to SJ, if the TV model number isn't listed, it won't work (as far as support goes), but we know that these guys aren't always right either.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LG 55LN5750-UH backlights
    I would remove an led and check size, pad polarity and pad configuration. I believe the problem is the lens are different not the led
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      How much LEDs does the 55" strip have and how much do the 50" have. If the difference is 1 or 2 per strip I would use the strips available.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        the lens isn't a problem. Those are still good on the set. It's just the LED's on which I am not sure on. Maybe just for heck, I am going to order them anyways.
        I have no idea how much LED's that 50" set has.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Shopjimmy is selling lens and led and I believe the lens are different which is why they don't list as compatible
          • unxtres
            • Aug 2017
            • 20
            Why not to resolder only bad leds? Why you want to change whole strip?
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              I don't care about the lens that comes from SJ, I just want the LED's to fit. All lenses on mine are still good. I've ordered the LED kit now anyway. Let's see what happens.
              I was looking for strips, so I can replace the bad Led / led strip on the set I have.
              • unxtres
                • Aug 2017
                • 20
                i found few LED tv with broken screen, you can get them for free or for some funny price.
                Rip them off and keep stripes for spares LEDs, i`ve done that and i`ve never need to buy new leds yet.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8352
                  Unfortunately one can't go to the recycling bin and take out stuff anymore. It's theft around here, go figure.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8352
                    Got the LED's from SJ, put them in with the old lenses. Works fine.
                    • Pipolups
                      Corsair K70 LUX RGB dying LEDs
                      by Pipolups
                      Hi there !
                      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                      10-08-2024, 11:58 AM
                    • edugimeno
                      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                      by edugimeno
                      Hi There!
                      I'm trying to help my friend who owns a restaurant be just bought.
                      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                      It's stuck using, I guess, the 2 sided tape that comes with the strip
                      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                      09-05-2024, 09:34 AM
                    • Eel_dahc
                      Samsung un60j6200 backlights
                      by Eel_dahc
                      Hi there.
                      My uncle's tvs leds went out.
                      I actually had some from a cracked tv that I picked up years ago.
                      I replaced them all except for 1 strip because I had cut one up for a project. He still had a couple that tested ok.
                      These are laid out 2 strips with 7 leds each in series. 3 strip sets in series, with another 3 strip set in series. A total of 84 leds. The power supply says it's 326v. 326/84 = 3.8v per led.
                      Well after I gave it back to him, 1 strip died 2 days later. The one that I didn't replace I guess.
                      03-18-2022, 08:42 PM
                    • m4a2t0t
                      Samsung UN55NU7100 Backlights
                      by m4a2t0t
                      I replaced the backlights in this unit and only half of them are now working. The strips were bad, I could see a few LEDs that blew up. The power supply outputs 190V to the LEDs in the working strip (1-2 and 3-4) and the non working LEDs (5-6 and 7-8) have 120V on + and 65V on -.. Using chassis as ground point. Any suggestions...
                      07-03-2024, 08:15 PM
                    • alltvrepairs
                      Backlights required for Blaupunkt 50UN265 (HK50D08-ZC56AG-01) - cannot find a source
                      by alltvrepairs
                      I am unable to locate a set of LEDs for this model. Maybe you know a better source: 4 Strips of 8 Leds per strip.
                      Tried with model or HK50D08-ZC56AG-01 but no luck so far.
                      Regards
                      07-06-2025, 08:29 AM
