Samsung un60j6200 backlights
  • Eel_dahc
    • Apr 2017
    • 18
    Hi there.
    My uncle's tvs leds went out.
    I actually had some from a cracked tv that I picked up years ago.
    I replaced them all except for 1 strip because I had cut one up for a project. He still had a couple that tested ok.
    These are laid out 2 strips with 7 leds each in series. 3 strip sets in series, with another 3 strip set in series. A total of 84 leds. The power supply says it's 326v. 326/84 = 3.8v per led.
    Well after I gave it back to him, 1 strip died 2 days later. The one that I didn't replace I guess.
    All of his bad strips were either 3 or four leds open or the whole strip shorted.
    So I was able to swap some individual leds around to repair around 4 strips.
    What's a best way to test them with a power supply?
    I tested the repaired ones on my bench supply at 21v (assuming 7 leds x 3v) and and they range from .15 to .16 amp draw. I didn't really want to up it to 27v (7 x 3.88)
    I'm not sure of what is the best way to stress test them, but I would like to know because I'd like to not have to open it up again. :-(
    The power supply for the TV seems okay, the D9001c diode is not shorted. Other than that I'm not sure what to check if that has a problem.
    I'd love to be able to drop the voltage from the supply or have a way to prevent spikes also.
    09-07-2024, 05:50 AM
  • max789
    Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
    by max789
    Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
    I made the following tests:
    1. Disconnected the main board from Power Board = backlight works.
    2. Connected the main board and disconnected the T-Con = backlights does not work.
    So I ordered a main board from Ebay also BN41-02156A but from...
    01-18-2024, 06:56 AM
  • smort
    Backlight Polkadarks
    by smort
    Soooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
    I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had...
    03-11-2025, 12:33 AM
  • m4a2t0t
    Samsung UN55NU7100 Backlights
    by m4a2t0t
    I replaced the backlights in this unit and only half of them are now working. The strips were bad, I could see a few LEDs that blew up. The power supply outputs 190V to the LEDs in the working strip (1-2 and 3-4) and the non working LEDs (5-6 and 7-8) have 120V on + and 65V on -.. Using chassis as ground point. Any suggestions...
    07-03-2024, 08:15 PM
  • edugimeno
    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
    by edugimeno
    Hi There!
    I'm trying to help my friend who owns a restaurant be just bought.
    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
    It's stuck using, I guess, the 2 sided tape that comes with the strip
    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
    09-05-2024, 09:34 AM
