Panasonic TX-40CX400B - 17IPS20 - DULLSCREEN+ON/OFF/ON/OFF fault
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Panasonic TX-40CX400B - 17IPS20 - DULLSCREEN+ON/OFF/ON/OFF fault
    maybe worth a read 5v is defently mentioned not sure if for standby though
    https://www.badcaps.net/forum/showth...hlight=17IPS20
    does the set fully boot if you freeze the eeprom/spi flash ics on the mainboard
    • R_J
      • 9553
      That post has a cleaner version of the schematic but all they do is take +12vcc through Q212 (base zenered) to get +5v Stby ( but shepp says q212 is not populated on this board)
      • shepp
        • Mar 2012
        • 377
        • England
        yes fully boots, maybe it has got 5v and I cant reach the pin on the plug to test it while its on, but I havent found any 5v signals on the top side while powering up, just reading the link......and been searching for a board for it but cheapest ones like ยฃ40
        • vinceroger69
          • Mar 2012
          • 6714
          so your saying if you freeze the spi flash ics the set boots further and stays on longer?
          i have some psu s in my spares boxes i will look through them tomorrow and see if i have one
          • shepp
            • Mar 2012
            • 377
            • England
            so your saying if you freeze the spi flash ics the set boots futher and stays on longer?
            im not quite sure what you mean? I havent froze the spi flash ics....I havent got a clue what that is
            but I am now checking U300 out and the surrounding components
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              if its a eeprom spi flash issue causing the reboots and freeze sometimes freezing the ics will make the set start up properly thats if it not a psu fault of course
              • shepp
                • Mar 2012
                • 377
                • England
                #27
                how do I freeze the ics?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  what mainboard does this set use ? and i use air duster spray hold the can upside down and spray the ics not as good as proper electronics freeze spray from maplin etc but certainly cheaper
                  • shepp
                    • Mar 2012
                    • 377
                    • England
                    #29
                    the main board is a 23292153, is the ICS located under the plastic cover? see attached
                    • Rictech
                      Panasonic SA-MAX770PU SMPSU board fault....
                      by Rictech
                      Hello everyone. ๐Ÿ˜€
                      As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                      Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                      Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                      This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                      There are no devices that have exploded or otherwise show signs...
                      08-26-2024, 01:05 AM
                    • chockimon
                      Panasonic TX-40AX630B has developed a fault
                      by chockimon
                      I bought a Panasonic 40" TX-40AX630B TV from Richer Sounds 7 years ago and it has developed a strange fault. If I attempt to press any button on the back of the TV or remote control (access media features etc.) the TV locks up for a few minutes or longer and sometimes goes blank. However, if I turn the TV off and on again and quickly select a channel it will work fine all day long, as long as I don't touch the remote or controls on the back of the TV.
                      I've tried changing batteries on the remote, changing plug sockets and doing other things such as a...
                      06-02-2022, 12:03 PM
                    • Andre Gilbert
                      by Andre Gilbert
                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here๐Ÿค”?
                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting ๐Ÿ˜‚.
                      11-20-2024, 08:52 PM
                    • fixxy88
                      Panasonic 55DX600u second fault - panel brightness pulsing on right side
                      by fixxy88
                      After getting the backlights up and running a second fault has emerged on this TV. I was going accept defeat and move on but thought I'd have a quick look at it in case it was something simple. The right side of the display exhibits a panel brightness (not backlight brightness) pulse every 2-3 seconds in a stable timing.
                      I poked about on the TCON test points and found one voltage that is fluctuating in the same pattern. VGH-ODD (Pin 47 of U10) is sitting at ~-6.5v then goes up to ~28v when the brightness pulses then goes back down to ~-6.5v again in a repeating pattern.
                      03-22-2023, 02:58 AM
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
