Polaroid P50D300S No picture
  • unxtres
    • Aug 2017
    • 20
    Black screen, there is sound and reaction for remote, backlight is also on
    I`ve tried to change T-Con but same issue
    Voltages on main and Psu are present there is also 12v on fuse on tcon
    any ideas?
    TV - Polaroid P50D300S
    Screen - VES500UNDA-2D-N11
    T-CON - T420HVN06.3
    MAIN - 17MB97
    PSU - Vestel 17IPS12
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Polaroid P50D300S No picture
    You got anything on your data lines to t-con? If you unplug one ribbon cable at a time going to panel what do you get?
    • unxtres
      • Aug 2017
      • 20
      nothing, screen are still black, no, lines nothing, i have also checked caps on screen electronics for shorts but everything looks good, this tv is like ghost
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Have you checked that you have a supply voltage to the tcon?
        Edit
        Oops, I see you have already checked.
        • unxtres
          • Aug 2017
          • 20
          Edit
          Yes and fuse are ok too, no shorts on ceramic caps
          Big IC on t-con also getting to be warm when tv is on
          Possibly firmware fault but i still i can change source (blindly) and there is sound in speakers.
            If you have a scope you can check LVDS lines for activity.
            One "hack" is to try partially disconnecting LVDS cable and seeing if you get patterns on the screen. I wouldn't do this too much, but a brief check to see if the panel is working at all may be helpful.
            My bet would be a bad panel.
            If you have an RS232 to USB adapter and some wires there's a way to get a debug port on the SCART port of the TV, this will let you log in to the operating system of the TV to have a fiddle with some settings or test modes.
            • unxtres
              • Aug 2017
              • 20
              tom66 looks like bad panel, tried disconect ribbon conections and there is nothing on screen, looks like dead.
              Im interested in this RS232 can you provide me some links or more info about it
                What's the motherboard model number? 17MBxx
                • unxtres
                  • Aug 2017
                  • 20
                  17mb97
                    Right... Can't find exact schematic but quick look shows same as other boards across the range.
                    You will need a USB to RS232 cable that accepts low voltage levels...MOST do, but some do not. If you do not have one then use this. NOTE most PC RS232 sockets will *not* work as they require the +/-10V logic levels that the TV will not use.
                    If you do not have one then use one of these:
                    http://www.ebay.co.uk/itm/2Pcs-Ardui...kAAOSw3lFZeGMf
                    I will assume you are using Windows.
                    First use software like PuTTY (https://www.chiark.greenend.org.uk/~...ty/latest.html) to use the serial port.
                    Enter your COM port number (you can find it in Device Manager on Windows) and baud rate 115200.
                    Tie the transmit and receive (TX and RX) of your cable/connector together. Then type. If characters are seen in PuTTY, your cable is working and set up correctly. (This is an echo test.) Note characters do not normally appear unless "echoed" by the receiver, therefore do not expect anything to appear when the cables are disconnected if you type.
                    Then you will want to connect the TX of your device to the RX of the TV, and RX to the TX of the TV. It is pin 12 that is the TV's transmit (TX) and pin 14 that is the TV's receive (RX). See this diagram for SCART pinout. (Note Vestel use the spare pins for the port.)
                    http://www.leadsdirect.co.uk/wp-cont.../scartdiag.gif
                    If all is well, when you turn on the TV, you will get a load of debug output. This may tell you if there is a problem in a specific area, for example unable to read a certain file which may be fixable via firmware update.
                    It should also prompt you to press a key to enter a terminal, which should let you enter the Linux operating system. If a password is requested, try "314159".
                    • unxtres
                      • Aug 2017
                      • 20
                      Thanks Tom that may be useful in future
                      Anyway i found that for this board 17mb97 RX are pin 10 and TX - 12
                      i need also to connect gnd to pin 14
                      i`ve got some strange output:
                      ▒/y▒▒L▒{▒▒f▒▒5▒n▒▒▒▒cvr▒▒▒▒▒▒,▒w▒▒▒h▒▒a▒q▒a8▒=▒t▒▒▒cS▒y▒▒▒▒▒w▒▒▒w▒M▒u▒▒W▒▒$▒5▒+Z▒x▒S▒▒▒▒j▒4▒▒▒▒▒▒▒▒▒▒sf▒▒▒▒▒oq▒ާsw|P▒cŵ▒▒#c▒m▒▒?-
                      i have uploaded service manual for that board.
                        You might need to experiment with different baud rates, 9600, 19200, 115200 and 230400 are commonly used; the series basically doubles between each value. You would need a scope to measure the bit period to know the exact baud rate.
                        • unxtres
                          • Aug 2017
                          • 20
                          i`ve tried different baud rates with highest value than 9600 ive got more data back but it is still unreadable :/
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            If the service manual is the one for your mainboard then it looks like the connections will be:-
                            SCART Pin 10 = UART Rx (Received data)
                            SCART Pin 12 = UART Tx (Transmitted data)
                            SCART Pin 14 = Ground
                            From page 58
                            • unxtres
                              • Aug 2017
                              • 20
                              From page 58
                              Yes it is connected in that way
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Do as Tom suggested and disconnect the Tx and Rx wires from the SCART connector and short them together.
                                Run the Terminal program and set the baud rate and echo character.
                                Whatever you type should now reappear on the computer screen so if you typed "a" then "aa" should show on the screen.
                                Once you have that, you can then disconnect the wires and reconnect them to the SCART inputs. You may have to swap the two wires over.
                                • unxtres
                                  • Aug 2017
                                  • 20
                                  dick_barton i receiving data from tv this is not issue with non working rs232.
                                  as i mentioned several posts ago,
                                  data that i receiving are not readable
                                  please tell me again what that operation will change? When i short rx tx and send a char ?ill get response same char and....?
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    I would say that it's stage one to know that what you transmit is what you are receiving so any corruption when connected to the scart socket must be a problem with:-
                                    1. Baud Rate
                                    2. Number of start bits
                                    3. Number of Stop bits
                                    4. Parity
                                    5. Number of data bits 7 or 8 bits
                                    All of which you can be varied in the communication program.
                                    This may be useful
                                    http://electronicshelponline.blogspo...-software.html
                                      The baud rate is the unknown, almost every system uses 8N1 Comms (8 bits, no parity, 1 stop, 1 start)
                                      • tn245
                                        • Oct 2013
                                        • 530
                                        You ever get anywhere with this? I've got a similar one with the 17mb97 board and no picture. The baud rate is 115200. I see it starting up on rs232 terminal but then it says UART disabled part way through start up and then nothing which is pretty useless as there's no way to see the menus to enable UART.
                                        • Fly_Among_Stars
                                          VIZIO E70-E3 Half picture with half TCON
                                          by Fly_Among_Stars
                                          I have a VIZIO E70-E3.
                                          Symptoms: Black screen, no picture, but LED backlights are working.
                                          I probed the power board and voltages are as listed on the board.
                                          Main board appears fine, too.
                                          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                          There are two separate ribbon cables feeding the LCD.
                                          If both are connected, the screen is black.
                                          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                          04-24-2023, 08:20 PM
                                        • iglitare
                                          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                          by iglitare
                                          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                          Backlight seems to work, Sound (Setup menu after reset) works.
                                          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                          With my small knowledge i would think at least the cables are good.
                                          Can this happen because of a bad tcon board?
                                          Or is it always a bad/shorted...
                                          09-04-2025, 07:13 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • shelby5041
                                          Samsung LCD TV no picture backlight on no 12v at tcon
                                          by shelby5041
                                          hi
                                          i have a samsung lcd tv
                                          it powers on with sound and backlight but no picture
                                          all voltages from PS are good 12v 3.3v and 5v
                                          whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                          i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                          no 12v at the tcon fuse
                                          i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                          the odds of having 2...
                                          10-08-2021, 08:21 AM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
