17pw20.1 board????
  • PhaseCoder
    • Nov 2013
    • 62
    • Uk
    17pw20.1 board????
    I picked up a TV, when been unplugged you can turn it on and watch for about 20 minutes, then cuts off to standby. Try to put it back on and the standby light flashes.
    I opened it up noticed just one cap bulging 100uf 50v one no other signs, tried replacing no joy.
    Now my question is I have been looking on ebay for a replacement board, and noticed the 17pw20.1(the one in my Xenuis 37") and the 17pw20.
    My question is can I put the 17pw20 in and be ok?
    thanks
    Re: 17pw20.1 board????
    Bad cap can look normal, you need to check Capacitance, ESR, Leakage Current, etc. Always a good idea to change caps as a set.
    • PhaseCoder
      • Nov 2013
      • 62
      • Uk
      Ok thanks, but my main question really is
      the board in tghere is 17pw20.1 can i put a 17pw20 or 17pw20 v2???
      • dskall
        • Oct 2016
        • 2905
        • usa
        Maybe check shopjimmy for interchanges
        • PhaseCoder
          • Nov 2013
          • 62
          • Uk
          Access Denied
          You don't have permission to access "http://www.shopjimmy.com/tvs" on this server.
          Reference #18.c4921602.1502323851.1c9cbf6
          thats from shopjimmy :/ anyone else get that
          • dskall
            • Oct 2016
            • 2905
            • usa
            I think you can use 17pw20.1 or a 17pw20. Don't know about V2
            • lpt2007
              • Aug 2018
              • SLO
              Anyone can share voltages on pl802, pl801,pl803, pl812 connectors pin on power supply 17pw20.1 when tv is off and on?
              Simptoms of my tv:
              When I plug the power standby led is on. Whe I press power button standby led goes to off but there is no picture on tv. When I press the power button again I get no respose.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                This should be your schematic which has voltages given.
                • lpt2007
                  • Aug 2018
                  • SLO
                  Thanks for schematic
                  Anyone have tv with symptoms like my tv and know where prolem is? I try to change inverter but no luck
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    It is best if you would name the connectors , pin name and number and also voltage at the pin which could well indicate what is wrong.
                      Originally posted by dick_barton
                      it is best if you would name the connectors , pin name and number and also voltage at the pin which could well indicate what is wrong.
                      +10
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        Simptoms of my tv:
                        What make and model number is the tv your working on
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
                        • Hakuu
                          by Hakuu
                          Hi There,
                          More Details
                          TV Model - LG OLED77G1PUA
                          07-12-2023, 02:37 PM
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                          After all of...
                          07-13-2024, 08:14 PM
