VIZIO P50 HDTV20A Plasma Distortion on Screen
  • CSF
    • Jul 2017
    • 28
    Re: VIZIO P50 HDTV20A Plasma Distortion on Screen
    You can see the snow in the video. Is that normal?
    Although when I compare the test pattern to the first video I posted I certainly don't see any of the same symptoms. There are no lines or blur in the test pattern.
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      that may just be because the voltages are out a bit. i was more concentrating on the distortion that no longer seems present.
      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
      • CSF
        • Jul 2017
        • 28
        Would anyone else care to offer some insight?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          I'm not a plasma man but you seem to have dark patches on the screen especially at the lower right hand side which I believe is a Xsus problem. If anyone can double check that this is correct I would appreciate it.
          • CSF
            • Jul 2017
            • 28
            I think that's the board that has been replaced, picture #7. It was supposed to have been tested. I'm certainly no expert either. Thanks for the input.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              Check the soldering carefully on the coils on the Xsus which tend to a cause of problems.
              • CSF
                • Jul 2017
                • 28
                I checked the connections, they look okay. I also put the old board back in and caused some distortion with the test pattern unlike the replacement board. The dark spot did no go away with the old board.
                I've run the test pattern a few more times and I do see flickering and some bright and dim going on. So I made an offer for a control board for $6. I'll try that and see if the test pattern improves. Then try plugging the main board back in, remove the jumper and see what happens.
                • CSF
                  • Jul 2017
                  • 28
                  I got the replacement control board. Put it in a the tv works great. The old control board didn't have a major distortion in the test pattern, but there was the same flickering and flashing going on. Thanks to everyone for your expertise and especially attainteddragon. I never would have gotten this far without your help. I have another tv I'll start on in a few days or weeks depending on funds. I picked up 4 tvs including the 50 Vizio for $60 and I was starting to wonder if I shot myself in the foot. It sure is fun when the tv comes on looking clear as a bell. Oh yeah the dark spot in the corner of the screen is gone too.
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    #29
                    awesome, glad it is all sorted.
                    • spice_disc
                      Vizio TV M50-C1 reboot cycle and static on screen
                      by spice_disc
                      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                      09-08-2024, 02:37 PM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • Alicat
                      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                      by Alicat
                      Stopped by this site trying to fix my parents Panasonic Plasma TV.
                      Model number is TH-50PZ85U
                      Power comes on and the red power light stays on solid.
                      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                      I also hear a few clicks.
                      I also think my parents said there was a thunderstorm and the TV failed after that.
                      Section 6 in the service manual talks about power and no screen,...
                      10-30-2024, 10:09 AM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
