LG 49UF680V: Fuzzy only NOT on settings
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    HI all. I have never seen anything like this in my entire life. When powered on, you get the menu for setup. Perfect. After all that and not in menu, tv becomes fuzzy. Any pointers? Tcon or mainboard?
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
    Re: LG 49UF680V: Fuzzy only NOT on settings
    Main board. I'd say corrupted flash memory. Maybe try a software update, failing that, new main board needed.
    • Hamie
      • Apr 2014
      • 1383
      +1 MAINBOARD
      This is the most common fault on all the UF series.
      LG should have recalled them all.
      • Hamie
        • Apr 2014
        • 1383
        Also I'd ad I got a working board for a 55uf860v exact same fault.
        Tried to keep the faulty board in circulation by swapping/copying the flash.
        Didn't work. Gave up.
        • speedypro
          • Feb 2013
          • 561
          • United Kingdom
          Sorry for late reply. Ive done a software update from the main menu but same. Guess I'll let the customer know. My spirit never took this one to even repair it lol.
          • RetroComputingGrotto
            New Toy UNI-T UTi260B - What Settings?
            by RetroComputingGrotto
            I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
            After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
            I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
            09-02-2025, 08:36 AM
          • i440bx
            Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
            by i440bx
            Hey there,
            I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
            The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
            It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
            As written above, I plugged in a new CMOS cell and checked...
            08-19-2024, 02:28 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • AquaMan Ua
            by AquaMan Ua
            05-17-2025, 09:40 AM
          • Billydv1@verizon.net
            Various Asus Motherboards losing bios settings
            by Billydv1@verizon.net
            Trying to track this down. 3 boards all same problem. Rampage IV Extreme, Z87 Pro, Z97 pro. All boot and function correctly but all lose bios and time settings if power is shut off. If power is maintained, sytrms boot and reboot normally. I have verified cmos battery is supplying 3v to board. 8 pin bios chip has continuity to ground but no voltage to vcc pin. I assume that's the pin that maintains the settings with power to bios chip. How do I track this down? What voltage do these bios chips require?
            11-30-2023, 10:27 AM
