Un55f9000 un65f9000
  • nomoresonys
    • 12307
    • U.S.
    Re: Un55f9000 un65f9000
    Look there if that's your board then any of the substitute boards should also work. https://www.shopjimmy.com/samsung-bn...f9000afxza.htm
    • nomoresonys
      • 12307
      • U.S.
      I would troubleshoot your mainboard, check everything you can, try freeze spraying your eeprom, then turn on tv see if anything changes.
      • llloco
        • Nov 2018
        • 9
        Clearly. Unfortunately your suggestion is about as useful as suggesting a cheap random board for a sony or other brand tv to fix this Samsung issue... but i do appreciate the effort.
        Part BN94-06654A is the "main board" I need. The main digital board that is responsible for the OPs listed troubleshooting symptoms....not main POWER board.
        • llloco
          • Nov 2018
          • 9
          Thanks. I already did did that search and none of the options are in stock that i can find except the expensive ones on ebay
          • nomoresonys
            • 12307
            • U.S.
            NO KIDDING??"?? No need to be a smartass, the board was a mainboard, if you had a picture and full description of your board, there would be no mixups.
            • nomoresonys
              • 12307
              • U.S.
              #26
              Looks like you are CLUELESS, why are you even trying to fix a tv? GIVE UP.
              • llloco
                • Nov 2018
                • 9
                Well now do you want to open that can of worms??
                Considering that I'm building on an original thread about the particular main board that I'm looking for I'm not too sure what you're getting your panties in a such knot over:
                first let me remind you that your first reply was clear clueless smartass attitude to my original post saying I'm looking for the board and it's going to cost me $1,200 unless someone has one to offer.... or did you forget your reply? But that's ok I overlooked it too.... until now. So before you go editing or deleting it why don't you read it again.
                Then you go telling me off for being a smartass for saying that while I appreciate your effort to show me a power board it's clearly not what is being asked for... and about as useful as showing me something completely unrelated just because the price is better. And all despite me politely replying to your first smartass comment with a link to the exact photo listing of the board required which is being described as the "main board".... Now that's clueless.
                It's ironic that despite that this thread is about the particular board I was looking for, and me replying with a link to a photo listing of the board needed I am apparently causing confusion??... Instead of bombarding me with multiple preconceived suggestions, which were already exhausted before reaching out on here (including the one you deleted), you could have just asked for clarification first... but I can already tell you are so above that...
                And let me guess I'm to think that you're not being rude by telling me to not bother fixing a TV because I am apparently Clueless? Clueless would be not asking for clarification before replying multiple times to a post. Clueless would be ASSUMING a power board was what I sought despite the background of this thread. Clueless is not checking the replied link, to your first SMARTASS post with a link to general ebay search over my comment about the board costing $1200, before suggesting a different board. Clueless is thinking I didnt already test the boards.
                You could have prevented all this by simply not being a smartass. I may be new to this particular forum but I think you're the one that is clueless.
                Dont bother firing back unless you actually have something useful to say. I'm done trying to be polite with your clueless smartass attitude.
                Go troll about elsewhere.
                • nomoresonys
                  • 12307
                  • U.S.
                  #28
                  Pm sent.
                  • masaudio
                    • 16
                    • England
                    #29
                    We have a UE55HU8500TXXU in the workshop,
                    Which comes on fine without the box plugged in, asking to plug in the box,
                    When the box is connected, the screen does nothing, just shows the white light at the bottm to say its on or off,
                    The box has the fan running inside, and the relay on the power supply in the screen is just clicking every 10-15 seconds.
                    I would have diagnosed it as the box, because the screen comes on without it..
                    but how would i tell if its mainboard in the set?
                    Mark.
                    • high-tech
                      Samsung UN55F7050AFXZA ver. TD01 power cycling
                      by high-tech
                      Hello everybody, I could use some help on this one... It's got me guessing...
                      I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                      (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                      (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                      (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                      (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                      9. ground (PWM2) 10. 0.9 volts cycling...
                      09-15-2020, 03:39 PM
                    • Teban1306
                      [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                      by Teban1306
                      Hello everyone!
                      I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                      System Information:
                      • Model: Lenovo ThinkPad T14 Gen 1
                      • Machine Type: 20S1S4E600 (Intel i7 variant)
                      • Current BIOS: N2XET42W (1.33) - Latest version
                      • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                      What I'm trying to achieve:
                      Replace the default "LENOVO" boot logo with a custom image during POST.
                      🔧 What I've tried:
                      09-14-2025, 11:49 AM
                    • Verlengsnoer
                      Bios splash/logo change
                      by Verlengsnoer
                      at firs, i hope this is the right place to post my question.
                      Im looking for a tool to change the bios logo.
                      everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                      i know that HP has a build in option to change the splash logo.
                      but i want to change the manufacturer logo to an own logo.
                      I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                      10-28-2022, 09:52 AM
                    • KYBOSH
                      Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                      by KYBOSH
                      I picked this one up today.
                      Previous owner says no signs of life.
                      TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                      Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                      The TV model is QN65LS03BAFXZA - version: CB06
                      The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                      I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                      Will keep you all...
                      04-05-2025, 08:32 PM
                    • usbdevice
                      Acer X223HQ (Version Bbd) on/off-power-cycling
                      by usbdevice
                      Hi all
                      There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                      https://www.badcaps.net/forum/showthread.php?t=50657
                      https://www.badcaps.net/forum/showthread.php?t=40512
                      The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                      It's my dad's old monitor. He...
                      08-05-2022, 02:21 AM
