LG Main board
    LG Main board
    Hi
    I'm pretty sure my main board is faulty as I can't get any free view channels
    I've tried a factory reset but it didn't solve the problem.
    My TV is 42LW551c-ze (this is a Hotel TV)
    Main board is - EBT61514204
    EAX64294002(1) 11.03.28 KDU
    When I do a search I get very few results for this TV, either they don't break
    or people just dump them.
    Any body out there know were I can source a replacement main board, or is there a fix, the TV is still being used through a set top box so it's not a real problem but I would like to get it working properly.
    Re: LG Main board
    Free view may be locked out in hotel mode
      Re: LG Main board
      Hi dskall
      Should have said already tried that, and it isn't that
        Re: LG Main board
        Tried updating firmware
          Re: LG Main board
          Hi dskall
          Thanks for taking the time to try and help me, I'm not sure I know what you
          mean, is it some thing to do with flashing the Eeprom, if so no and I would definitely need some help on that.
            Re: LG Main board
            No , you need to search for the firmware for this specific model. Normally you can find it on the LG website , download it , save it on USB and apply it via the system settings/menu etc.
            Same as on your mobile phone when it searches for updates.....
              Re: LG Main board
              Hi Moreno83
              Having checked I have the latest Firmware so that's not the problem, thanks
                Re: LG Main board
                check the solder joints on the tuner. they can break free sometimes.
                when you run a channel scan, do you get any static flicker when it almost picks up a station, or is there nothing at all?
                WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                  Re: LG Main board
                  Did you get into the service menu rather than the usual set menu?
                    Re: LG Main board
                    Hi
                    When I do a channel scan it goes to 50% then finishes there is no flicker nothing happens, and it's the set menu I think as I'm not sure about the service Menu and how to get into it.
                    Regards
                      Re: LG Main board
                      Depending on model there are a few ways to access service menu just do a Google on it, also other hotel menu password 1507 I think. In other makes I know hotel mode can be switched on or off in service menu.
                        Re: LG Main board
                        Tried service menu and every thing in there is OK, So unless I can find a bad solder joint on the Tuner it looks like it's the Main board. Unfortunately
                        they are very hard to come by.
                          Re: LG Main board
                          when you was in the service menu did you try a factory reset if not it maybe worth trying
                            Re: LG Main board
                            Yes I've tried a factory reset and it don't solve the problem.
                              Re: LG Main board
                              worst case scenario, you could always use a receiver.
                              i know a repair is always better, but sometimes you just have to cut your losses.
                                Re: LG Main board
                                I think you are right, we will keep using it through the set top box, and I'll keep my eyes open for a replacement main board.
