LG Main board
  • Doverdave
    • Jul 2017
    • 11
    LG Main board
    Hi
    I'm pretty sure my main board is faulty as I can't get any free view channels
    I've tried a factory reset but it didn't solve the problem.
    My TV is 42LW551c-ze (this is a Hotel TV)
    Main board is - EBT61514204
    EAX64294002(1) 11.03.28 KDU
    When I do a search I get very few results for this TV, either they don't break
    or people just dump them.
    Any body out there know were I can source a replacement main board, or is there a fix, the TV is still being used through a set top box so it's not a real problem but I would like to get it working properly.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LG Main board
    Free view may be locked out in hotel mode
    • Doverdave
      • Jul 2017
      • 11
      Re: LG Main board
      Hi dskall
      Should have said already tried that, and it isn't that
      • dskall
        • Oct 2016
        • 2905
        • usa
        Re: LG Main board
        Tried updating firmware
        • Doverdave
          • Jul 2017
          • 11
          Re: LG Main board
          Hi dskall
          Thanks for taking the time to try and help me, I'm not sure I know what you
          mean, is it some thing to do with flashing the Eeprom, if so no and I would definitely need some help on that.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Re: LG Main board
            No , you need to search for the firmware for this specific model. Normally you can find it on the LG website , download it , save it on USB and apply it via the system settings/menu etc.
            Same as on your mobile phone when it searches for updates.....
            • Doverdave
              • Jul 2017
              • 11
              Re: LG Main board
              Hi Moreno83
              Having checked I have the latest Firmware so that's not the problem, thanks
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                Re: LG Main board
                check the solder joints on the tuner. they can break free sometimes.
                when you run a channel scan, do you get any static flicker when it almost picks up a station, or is there nothing at all?
                WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                • maxvalutech
                  • Dec 2014
                  • 804
                  • australia
                  Re: LG Main board
                  Did you get into the service menu rather than the usual set menu?
                  • Doverdave
                    • Jul 2017
                    • 11
                    Re: LG Main board
                    Hi
                    When I do a channel scan it goes to 50% then finishes there is no flicker nothing happens, and it's the set menu I think as I'm not sure about the service Menu and how to get into it.
                    Regards
                    • maxvalutech
                      • Dec 2014
                      • 804
                      • australia
                      Re: LG Main board
                      Depending on model there are a few ways to access service menu just do a Google on it, also other hotel menu password 1507 I think. In other makes I know hotel mode can be switched on or off in service menu.
                      • Doverdave
                        • Jul 2017
                        • 11
                        Re: LG Main board
                        Tried service menu and every thing in there is OK, So unless I can find a bad solder joint on the Tuner it looks like it's the Main board. Unfortunately
                        they are very hard to come by.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          Re: LG Main board
                          when you was in the service menu did you try a factory reset if not it maybe worth trying
                          • Doverdave
                            • Jul 2017
                            • 11
                            Re: LG Main board
                            Yes I've tried a factory reset and it don't solve the problem.
                            • attainteddragon
                              • Apr 2013
                              • 764
                              • australia
                              Re: LG Main board
                              worst case scenario, you could always use a receiver.
                              i know a repair is always better, but sometimes you just have to cut your losses.
                              • Doverdave
                                • Jul 2017
                                • 11
                                Re: LG Main board
                                I think you are right, we will keep using it through the set top box, and I'll keep my eyes open for a replacement main board.
                                • Dani_2024
                                  by Dani_2024
                                  10-28-2024, 05:06 PM
                                • ygorsan
                                  by ygorsan
                                  🧩 Problem Summary:
                                  • I
                                  07-28-2025, 08:34 AM
                                • jb_Bak
                                  by jb_Bak
                                  CN6401
                                  Pin 01 NC
                                  Pin 02 NC
                                  Pin 03 "BL_ON": 0V
                                  Pin 04 "N/C"
                                  Pin 05 "STBY 3.3V": 3.5V
                                  Pin 06 "GND": N/C
                                  Pin 07 "AC_OFF"...
                                  09-27-2021, 04:52 PM
                                • JDC
                                  by JDC
                                  ONN 100012588
                                  Long answer:
                                  07-15-2022, 07:39 AM
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
