Sharp LC-37x20e power on but only for few seconds
    Re: Sharp LC-37x20e power on but only for few seconds
    Can we see good closed up pictures of the top and the bottom side of the board around the area where you replaced the IC7601?
    • clamel
      • Jul 2017
      • 20
      • Italy
      IC7601 was copy and paste error.. I had to replace IC7904.. summarizing:
      IC7904 (9NK2510293234) TNY264PN --> It was very HOT. Replaced because it burnt after freezing. But during freezing it, the TV power came to life for some seconds, before this component burnt definitively.
      R7920 replaced because damaged after IC7904 burnt
      R7918 replaced but it was good
      IC7906 PC123Y82FZ0F --> Replaced, but after desoldering repeating tests on the old it had no problem.
      In attach some photo centered on IC7904, but also other replacements are visible.
      thank you very much for your patience
        Is the snubber diode D7906 tested OK?
        • clamel
          • Jul 2017
          • 20
          • Italy
          yes, It seems to working fine.. with multimeter in diode mode, I read 0.479 V in one way, and OL in the other way. The readings are done with component soldered on the board.
          • clamel
            • Jul 2017
            • 20
            • Italy
            I made some voltage measurement with power board connectet to AC.
            IC7904 - TNY264PN (using PIN2 as GND)
            pin1 - BP 5.85V
            pin2 - S 0V
            pin3 - S 0V
            pin4 - EN/UV 12.8 mV
            pin5 - D 309V
            pin7 - S (HV) 0V
            pin8 - S (HV) 0V
            I also measured voltage at some near components
            D7906 13V
            D7905 7.4V
            C7907 5.85V
            D7910 4.22V
            Is IC7904 working properly looking these voltages? What can I check in next steps?
            thanks
            BR
            • clamel
              • Jul 2017
              • 20
              • Italy
              #26
              Maybe ic7904 I replaced is bad? I don't undestand why I get only 1v instead of 5v
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • liquidzorch
                Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                by liquidzorch
                Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                10-18-2024, 05:19 PM
              • Mita99
                Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                by Mita99
                Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                04-27-2025, 07:20 PM
                by sam_sam_sam
                03-31-2024, 02:12 PM
