LN40C540F2F 6 blins then dead unit
  • kgavionics
    • Apr 2017
    • 152
    Hi i have a samsung LN40C540F2F i want to fix.when i put the power plug the red light flashes 6 times stops and remain like that.
    i took the unit apart and measured the voltages ( see picture)
    the powerboard seems to be good according to the voltages and no bulging caps.
    the backlight is working fine if i unplug the connector between the PSU and the mainboard ( saw this trick online with this particular set)
    i suspected the mainboard not sending the PS_ON voltage (0.9V), but i have read a post here in this forum a guy had 0.8V and the tv was working fine.
    i'm leaning toward the mainboard, but i would like to have your input please
    thanks in advance
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: LN40C540F2F 6 blins then dead unit
    your ps-on is most likely good. some of these newer sets only need around .8v
    you are missing your back light on signal though, so your issue will be main board.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • kgavionics
      • Apr 2017
      • 152
      thanks attainteddragon
      when i remove the connector between the mainboad and the PSU i get the backlight and the pin BLU_ON is pulled high (5V).
      i'm planning to fix the mainboard, because i have fixed a few of them on the past.Hopefully, the problem is not coming from a chip, otherwise it's fixable.
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        mainboards are never fun. i look forward to seeing how you go.
        • kgavionics
          • Apr 2017
          • 152
          Yeah! you're right!!!wish me good luck
          • kgavionics
            • Apr 2017
            • 152
            i'm looking for the schematic of the main board, but i can find it.the serivice manual i have doesn't have any schematics of any board.can someone help me to find a service manual including the schematic of the mainboard?
            thanks in advance
            • dskall
              • Oct 2016
              • 2905
              • usa
              Not likely you going to find schematic for main board. Most service manuals now are rebadged owner manuals. Manufactures don't want their tv's to be repaired
              • kgavionics
                • Apr 2017
                • 152
                The best service manuals i came across are Sharp , panasonic and sony, they are so detailed and the schematics are well drawn.The Samsung service manual have is crap in my humble opinion.In their troubleshooting flow chart, i didn't find any case of 6 blinks.Knowing this will help me finding out if the problem is coming from a chip or just a simple component.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  While monitoring ps-on and pushing power button you get no change
                  • kgavionics
                    • Apr 2017
                    • 152
                    PS_ON remains 0.9V no change.
                    i checked the mainboard with my oscilloscope and i can't see any activity ( no wave forms),the only wave form i have is the crystall sine wave of 24 MHZ.so either the maincircuit is not working ( it's a BGA chip maybe a reflow can solve the problem) or it's not biased corrctely due to a bad component ( voltage regulator , diode, transistor..)
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      And you get your various main voltages
                      • kgavionics
                        • Apr 2017
                        • 152
                        the voltage on the regulator seems right, but i'm not quite sure,because without schemtic hard to tell if it's right or wrong.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          Common main board voltages: 1.1v, 1.8v 3.3v 5v 9v 12v 15v
                          Should be a number of voltages to check
                          • kgavionics
                            • Apr 2017
                            • 152
                            i've measured 1.8V,3.3V,5v and 12V,but never came across 1.1V,9v and 15V.i'll test again and report back.
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              Those are just common voltages. Not specific to all. Unfortunately one size does not fit all. If you found a 4v or 7v or .8v etc. those would be uncommon and suspicious
                              • kgavionics
                                • Apr 2017
                                • 152
                                I tested pretty much all the semiconductors and they seems alright.
                                So, i went and heated the mainboard for 1min on the oven and guess what,the tv worked on time only.grrrr!!!!
                                • jamesp
                                  Acer Aspire A315-55 Dead mainboard
                                  by jamesp
                                  Hello, can someone please help me. i have a dead laptop mainboard, aspire a315-55 with board model DA0ZAWMB8G0 rev. G
                                  upon checking of voltages at s5, 19v is present Vin, 5v and 3v is present at PL6001 and PL6000 respectively, but no signal from MAINON And s5_ON to be able to produce +3v_s5 to give power to vcc of BIOS CHIP U2. MAINON and S5_ON is coming from ec chip U37 it8987e/cx.
                                  do i need to reflash the EC? any advice? thanks...
                                  09-30-2024, 08:24 AM
                                • 3mz3t
                                  ThinkPad T14 Gen1 Intel, dead mainboard
                                  by 3mz3t
                                  NM-C931 mainboard, does not start, no light, no nothing. Draws 20.56 V / 0.14 A from a wall charger.
                                  Under thermal camera, the only thing that show is the ThinkEngine chip (BD4179MWV / UTE1B) heating up (also quite hot to the touch), there's 19.75 V on the VREGIN20 (pin 45).
                                  Is the BD4179 dead? WDYT?
                                  Thank you....
                                  08-05-2024, 04:59 AM
                                • Mirenia
                                  Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                  by Mirenia
                                  I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                  I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                  In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                  The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                  03-30-2025, 06:47 AM
                                • double_DD
                                  How can I be sure that my EC chip is dead?
                                  by double_DD
                                  As the title suggests, how can I be sure that my EC chip is really dead?
                                  I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                  Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                  03-12-2025, 07:47 AM
                                • orcic
                                  MASTER TL240 and new mainboard LW36BKC01
                                  by orcic
                                  I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                                  The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                                  After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                                  Now I have some doubts about how to connect the new mainboard to the old power supply.
                                  First of...
                                  05-12-2023, 08:10 AM
