Sharp 60" LED Weird Screen Issue
  • Cinhil
    • Jul 2017
    Hey Guys!
    Thanks for taking a peek and looking at this, I've been hammering away for abit at the problem, as well as replacing and swapping out the TCON/Main Board, My suspicion is still one of the two but would like to bounce the ball off the wall here and see what your thoughts are.
    Started having a few issues where it was snowy then got it cleared up, this this started to happen, I can trigger the black areas to go white by flipping off a ribbon cable and all the back lights are on and working.
    Image of the screen:::
    http://i.imgur.com/7UMT1iF.jpg
    I've delt with alot of TV's and don't do it professionally but all the TV's in my house are from dump/curbs and repaired, this is a first i've seen this and at a bit of a loss.
    Any info is good info! toss it out and i'll test it and see if it goes! on my spare time ofcourse!
    Thanks again for all your time!
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Sharp 60" LED Weird Screen Issue
    looks like over half panel going black.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • wizard13
      Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
      by wizard13
      I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
      I have checked the forum and the available documentation but could not find a solution specific to my issue.
      • Brand & Model: Dynabook Satellite Pro C50D-B-100
      • Part Number (P/N): PYU13E-00C00PFR
      • Serial Number (S/N): 22028896H
      • System Configuration (SC): A1PYU13E1127
      • Motherboard Model: IP3_ACN16_MB_V21_20211222A
      • Power Input: DC 19V –
      02-28-2025, 02:43 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • cloudy
      HELP - Contrast/brightness issue with subtitles on screen
      by cloudy
      Hi everybody
      Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
      Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
      Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
      It occours both on ubuntu and windows...
      01-01-2023, 05:12 PM
    • EazyBone
      Sharp LC-65Q620U White Screen
      by EazyBone
      Another TV topic!!
      I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
      The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
      Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
      08-21-2024, 12:56 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
