Vizio SV420M green vertical lines
  • tibimakai
    • Jan 2012
    • 3680
    It's been a while, since I have posted here.
    I have got this TV, from a coworker for free and I'm trying to repair it.
    I have replaced the T-Con board, since it was a couple of bucks, but nothing changed.
    I'm measuring the voltages and they are all there.
    Removed ribbon cables, re-inserted them again, with no change.
    Any ideas, what else can I try?
  • CapLeaker
    Leaking Member
    • 8352
    Re: Vizio SV420M green vertical lines
    I'd change the main board.
    • tibimakai
      • Jan 2012
      • 3680
      I suspect the mainboard as well, but it is not available, or it is over $100 which is not worth it.
      Do you think, that it would be a bad/old capacitor?
      • petehall347
        • Jan 2015
        • 4449
        • United Kingdom
        have you tried different sources ?
        • CapLeaker
          Leaking Member
          • 8352
          i doubt it, but you could easily find out by heating up the caps. just for heck... flex or squeeze the frame a little
          • tibimakai
            • Jan 2012
            • 3680
            Didn't try different sources. You are thinking analog source?
            • petehall347
              • Jan 2015
              • 4449
              • United Kingdom
              any source .
              • tibimakai
                • Jan 2012
                • 3680
                I have tried only HDMI 4. The menu has the same issue as well.
                • brad2157
                  Vizio E70-E3 Two white vertical lines
                  by brad2157
                  I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                  Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                  Replacement main board - Boots up fine, but starting...
                  12-13-2021, 05:11 PM
                • pni
                  LG 49uf695v vertical coloured lines
                  by pni
                  Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                  11-14-2025, 03:15 AM
                • viking509
                  vizio e65 e3 LED tv color vertical lines center tv only
                  by viking509
                  I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                  03-21-2023, 12:48 AM
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
                • 265chemic
                  Samsung LA46A950 aka. LN46A950 - intermittent vertical green lines / distortions
                  by 265chemic
                  Hi All,
                  I have a Samsung LA46A950 that intermittently was displaying issues with evenly spaced vertical green lines only on dark / black areas - this has progressed to more often and blue lines sometimes, as well as a little image distortion.
                  My initial suspicion was the T-CON board, which I took out and cleaned but the issue persists. A heat gun on all of the control boards makes no noticeable change. Ive also reseated the T-CON to panel ribbons (4 of them) and moving them while the panel is on doesn't seem to change the issue.
                  Below are some photos...
                  03-23-2022, 04:53 PM
