PANASONIC TC-P60UT50 Dark green fuzz on 1/3 of the screen
  • adabbledoo
    • May 2017
    • 6
    • usa
    I have already replaced the X and Y sus boards in effort to fix the problem. Neither helped at all. Is my panel dead could be just a buffer board issue?
    Re: PANASONIC TC-P60UT50 Dark green fuzz on 1/3 of the screen
    This looks more like a bad A-board than a panel defect. It's worth checking the cables from the A board to the C boards along the bottom of the screen are well seated.
    NOTE: If you remove the C boards, ensure the heatsink plate for the panel drivers is secured down after replacing it. If not, your panel drivers will overheat and you will need a new panel.
    • adabbledoo
      • May 2017
      • 6
      • usa
      I'll go over them tonight when I get home.
      Is there anything else I should be doing to check the A board?
      And duely noted about the heatsink plate
        Check all other cables are seated. Try pressing the various chips on the board with moderate force (don't flex the board too much) to see if it affects the image displayed. Try the test patterns in the service menu; see slide 37:
        • jimjoe123
          LCD TV Green/Pink screen problem
          by jimjoe123
          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
          Then each time...
          02-23-2020, 01:29 AM
        • kokos
          LG 55EG910v (Green Nosie Screen) BURNT on NOT ?
          by kokos
          Hi ! to all fellows out there!
          I have an LG 55inch 55RG910V-ZB Curved TV. With the following problem: When I turn it ON with Remote I get a Green noise Screen (attached foto).
          I have tried reseating all ribons, Checked PSU 24V,12V,3v ,etc voltages.
          The TV opens on the first Green noise screen and it freezes there -no respone of menu keys ,etc -only on/off via Remote. (I also noticed carefully that except from green noise screen there is a ghost image at bottom and left vertical side)
          I tried connected the lan and I can seee TV via local lan (as a device I...
          02-26-2024, 10:48 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • String2016
          samsung np300e green screen
          by String2016
          I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
          07-26-2025, 04:00 AM
        • Chrissygizmo
          Panasonic TX-48CX350B backlights but white screen , blank screen
          by Chrissygizmo
          Hi all, I’ve got a problem I hope someone can help me fixi.
          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
          01-11-2025, 03:18 PM
