KDL-55NX720 Pwr Led Blinks 5 times
  • fcisolutions
    • Jan 2017
    • 205
    From another post where this same Sony model was blinking 4 times I found this:
    CoppellTVRepair wrote:
    Haven't figured it out yet, partially because of Sony's idiotic design where if anything is disconnected (or failed) the whole TV shuts down ...
    Looking up the 5 blink code says I have a bad panel. But what is frustrating is if I disconnect everything related to the panel and I still get the same 5 blinks.
    Voltage readings:
    1 - 3.25v - Power_ON ----------2 - 0v - NC
    3 - 3.30v - PFC_ON ------------ 4 - 0v - NC
    5 - 0v - NC ---------------------- 6 - 1.67v - BL_ERR
    7 - 2.75v - AC_OFF_DET ------- 8 - 0v - T-CON_ON
    9 - 0v - GND ------------------- 10 - 3.3v - STBY3.3V
    11 - 0v - AU_GND ------------- 12 - 10.7v - AU_12V
    13 - 0v - AU_GND ------------- 14 - 10.7v - AU_12V
    15 - 0v - GND ----------------- 16 - 10.7v - REG_12V
    17 - 0v - GND ----------------- 18 - 10.7v - REG_12V
    19 - 0v - GND ----------------- 20 - 10.7v - BOR_ASU_12V
    21 - 0v - GND ----------------- 22 - 10.7v - BOR_ASU_12V
    23 - 0v - GND ----------------- 24 - 10.7v - TCON_VCC_12V
    25 - 0v - GND ----------------- 26 - 10.7v - TCON_VCC_12V
    27 - 0v - GND ----------------- 28 - 10.7v - TCON_VCC_12V
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: KDL-55NX720 Pwr Led Blinks 5 times
    If you unplug the 12v stuff do you still get 10.7v?
    • fcisolutions
      • Jan 2017
      • 205
      The main board has been isolated, forced power supply on, by jumpering standby to power_on and the 12V rail came to 12.75V.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Possible bad cap on 12v supply. Probable short dragging down voltage
        • fcisolutions
          • Jan 2017
          • 205
          Are you thinking the bad cap is on the main? Remember the power supply puts out the right voltages when the main is disconnected/isolated. Do you think replacing the main board is our best bet?
            You can try using 1A load on that 12V output to see if it can even handle 1A load to start with. The PFC Boosted Voltage also staying at around 380~400V range?
            • fcisolutions
              • Jan 2017
              • 205
              To use a 1A load would I put a 12ohm resister from 12v to ground?
              • fcisolutions
                • Jan 2017
                • 205
                And the PFC is 393v when I power the supply with a 1k resistor (eliminating the main).
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  12V, 12W car bulb would do the job
                    The cold resistance of the lamp may trip the over current circuit, the cold resistance of the lamp can be about 15 times lower than the hot resistance.
                    • fcisolutions
                      • Jan 2017
                      • 205
                      The power supply (w/o main connected) is forced on via 1k resistor to standby voltage and then I wired a 12v, 1.3amp fan from the 12v rail to gound. The voltage dropped from 12.75 to 12.44 with the fan running at full speed. PFC is stable at 392v during this test.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        I would start disconnecting 12v loads one at a time till voltage comes up
                        • fcisolutions
                          • Jan 2017
                          • 205
                          With the main disconnected and everything else plugged up 12v is good. Going to try ordering a main board. Thanks for your help.
                          • fcisolutions
                            • Jan 2017
                            • 205
                            Main board arrived and the voltages stabilized. But still no picture. The problem is, isolating seems to trigger the led to blink 5 times. For example, I connected just the main and I get the 5 blinks. So how is a tech suppose to troubleshoot?
                            Also I don't get the LEDs to light. There is a LED driver brd responsible to send the BL-ON turn on voltage to the secondary power board. Thanks Sony.
                            • fcisolutions
                              • Jan 2017
                              • 205
                              I was able to test the leds and each string (there was 4) was pulling 30volts. So looks like leds are good.
                              • nuala
                                • Aug 2013
                                • 37
                                Service manual for 5 blinks is t-con error/panel ID NVM error. T-com control MT board.
                                • fcisolutions
                                  • Jan 2017
                                  • 205
                                  Yes that's right. But remember, I get 5 blinks whether I have just the main board connected or main, led driver or main, led driver, tcon or main, led driver, tcon, and panel.
                                  • Biruslapio
                                    Panasonic P58V11B 8 and 12 blinks error "fix"
                                    by Biruslapio
                                    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                    04-13-2021, 07:13 AM
                                  • Andre Gilbert
                                    by Andre Gilbert
                                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                    11-20-2024, 08:52 PM
                                  • Taurus12
                                    Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                    by Taurus12
                                    Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                    I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                    i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                    Any recommendation on what I have to do next? Thanks in advance
                                    06-10-2025, 05:05 PM
                                  • jchon
                                    Sony A1e 5-blinks help
                                    by jchon
                                    Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                    I found the service manual, which was critical to know where to probe.
                                    https://www.manualslib.com/manual/20...1e-Series.html
                                    With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                    Unfortunately the 5-blinks...
                                    06-28-2023, 11:52 AM
                                  • mmischni
                                    Panasonic Viera Plasma TH-42PX75U 7 Blinks/8 Blinks/burned P board?
                                    by mmischni
                                    Greetings friends,
                                    I have a Panasonic TH-42PX75U manufactured in 2007. It has been trouble-free until recently. One evening I turned it on and it then powered back off and gave 7 blinks.
                                    First a question about the blinks. Everyone only speaks of a single number of blinks. I noticed on my TV, it blinks one fewer times for the first group of blinks, then blinks the full number repeatedly. So for my first code in question, the TV switches off, blinks 6, then blinks 7 repeatedly. When I disconnected the SC board, the TV switches off, blinks 7, then blinks 8 repeatedly....
                                    09-06-2017, 08:52 PM
