OMG SAMSUNG UN55F9000 Ultra HD, SMART, 3D 4K
  • tayker
    • Dec 2017
    • 6
    • barcelona
    #61
    Re: OMG SAMSUNG UN55F9000 Ultra HD, SMART, 3D 4K
    we are in the same situation.
    The T-con can not be the culprit because when disconnecting the cables the LCD is black.
    The fault must be in the RFC or in the main board. I will continue measuring tensions hoping to find something out of place, but I would bet for a firmware problem in some memory chip.
    : eek:
    • tayker
      • Dec 2017
      • 6
      • barcelona
      #62
      Investigating on the internet I always end up in the conclusion that it is a problem of the main board BN94-06650B
      • freakaftr8
        • Oct 2012
        • 3743
        Like I said before the one I had here for a customer had the same fault replacing the main board straightened the problem out. The mainbaord you received and the replacement are both probably bad
        • tayker
          • Dec 2017
          • 6
          • barcelona
          #64
          Thanks for the reply. It would be good to detect if there is any defective component before ordering a replacement motherboard if it is found. Or if it's a software problem in the memory chips
          • freakaftr8
            • Oct 2012
            • 3743
            It most likely is some out of spec voltage regulator. Or eeprom.
            • tayker
              • Dec 2017
              • 6
              • barcelona
              #66
              Hello after this long Christmas!
              I have returned to my favorite hobby with the f9000.
              I can say that I have changed regulators and flash memories and I continue with the same white pattern with the yellow strip above and the cyan below.
              If someone comes up with any other solution.
              I will continue investigating.
              regards
              Attached the copy of my eeprom of the motherboard
              • Nick's Tvs
                • Jan 2014
                • 621
                You have a bad main board. This is a common failure with these models. There are a lot of different parts that can fail on the main board and cause this issue, so finding the bad part is always a guessing game with these.
                There are no more main boards available for sale online, unless you go to encompass and want to spend $600, but there are some much cheaper repair services available online such as the one linked below:
                https://www.ebay.com/itm/Repair-Serv...4AAOSwHEZZeSdg
                • Unspun01
                  • Jun 2011
                  • 349
                  Tayker: Thanks for uploading the EEPROM. Which chip is this from?
                  Please clarify which EEPROM you replaced and re-programmed with the old .BIN file?
                  There are TWO Winbond EEPROM chips on this board IC3301 and IC3701. Perhaps the issue is with a different EEPROM?
                  I've had problems with bad Winbond flash chips on several other TVs so I suspect it could be bad EEPROM as well, but which one did you replace/reprogram? Can you also replace & reprogram the other one? and upload the .BIN file for it?
                  There are also several other 24CXX EEPROM chips on the board but I seldom see those as the issue.
                  See attached photo for Winbond IC locations:
                  • Unspun01
                    • Jun 2011
                    • 349
                    Tayker:
                    What if the .BIN file you read and re-programmed to a new EEPROM was corrupt?
                    Can anyone out there with a working UN55F9000 or UN65F9000 mainboard read the contents of Winbond EEPROM IC3301 and IC3701 and share the .BIN files here?
                    Maybe we can compare the dumps for possible corruption, or at least determine if reprogramming our EEPROM chips will repair the TV.
                    Thanks.
                    • tayker
                      • Dec 2017
                      • 6
                      • barcelona
                      #70
                      Hello Unspun
                      I did the dump on the IC that you call IC3301.
                      Also I did dumps of 4 or 5 IC and all it were correct.
                      So I think the failure is probably more complex.
                      My TV is UE65 but in the end I got an UN mainboard, as Nick's TV said ,and I have it working in the UK region even though I am in Catalunya
                      but it works correctly
                      • beastaS
                        • Apr 2018
                        • 13
                        #71
                        Originally posted by f67bird
                        Submitting the UA55F9000 service manual which is the European version of your set. It may be named UN55F900 though...along with the fast track for the UN55F9000 to Toms manuals in the tv repair reference library section.
                        Not sure how long it will take to go thru and be viewable there.
                        Hi, I'm looking for the service manual for my TV which is a UE55F9000STXXU. I tried using the keywords you mentioned but couldn't find them still. Can you help me out please?
                        • Silvanop
                          • Jun 2018
                          • Italia
                          #72
                          Originally posted by Michale32086
                          As Tom Cruise said in A FEW GOOD MEN "I don't know what all that means, but it sounds pretty bad..."
                          Hi Michale,
                          did you managed to find out the problem? I've got same thing:
                          https://ibb.co/jkc0yT
                          I got a replacement ONE CONNECT box...
                          I now get a good solid backlight when I power up the TV...
                          Nothing in the way of picture or display, but a good bright backlight..
                          If i got it right, it's normal colours if OC is not connected, never used it without. So it can be OC gone bad? After replace new OC you had no more yellow/white/blue/green strips?
                          It was working without problem and just died.
                          • Unspun01
                            • Jun 2011
                            • 349
                            Silvanop:
                            As Tayker, myself and others have found out, the problem with white screen and yellow/cyan pixelated artifacts is caused by MAINBOARD.
                            Even with One Connect detached from the TV, there should be an animated graphic showing you to attach the One Connect to the TV.
                            Replacing the mainboard with a known working one should fix the TV.
                            On another note, I still haven't managed to determine the issue with my bad mainboard - I've done voltage testing between my good and bad boards (inconclusive), so I still suspect a bad EEPROM chip or faulty memory causing corruption or something... has anyone else made any progress?
                            • Silvanop
                              • Jun 2018
                              • Italia
                              #74
                              Thank you, do you have some good site for mainboard in Europe?
                              • Silvanop
                                • Jun 2018
                                • Italia
                                #75
                                I can't edit my message, so start new one.
                                Some info here, someone can understand him?=)
                                https://www.youtube.com/watch?v=SDTzLE4tPLI
                                What you use to read this chips?
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4529
                                  • Italy - Milan
                                  #76
                                  Hi, i've followed the same case in Italian forum, on the mainboard, apply resistances on the power supply lines that goes to OC (3,3v 5v 13v) approx 500mA each or higher, then see if the tv doesn't power on, if yes check IC3603 near OC connector, try with freezer spray to let it to power on with the load resistances or OC connected.
                                  Or replace it or even the other one equal to IC3603.
                                  • Unspun01
                                    • Jun 2011
                                    • 349
                                    Silvanop: I don't understand his language, but in that youtube video, he completely replaced the faulty mainboard from his UA55F9000 4k TV with an aftermarket universal LCD LED TV controller driver mainboard (VS.T56U11.2) programmed with the firmware to operate the 4k Samsung panel. It is not a repair of the mainboard, but rather a clever work around.
                                    By using this replacement, you sacrifice the Camera, WIFI, and One Connect features in exchange for use of the panel and some input connections on the replacement mainboard.
                                    Very interesting. The VS.T56U11.2 LCD LED controller can be found here:
                                    https://www.aliexpress.com/item/free...862667961.html
                                    Some information on how to program the controller can be found here:
                                    http://lcd-ledtvfirmwares.blogspot.c...ed-tv-usb.html
                                    and searching VS.T56U11.2 on youtube turns up some absolute wizardry that I don't have time to figure out such as:
                                    https://www.youtube.com/watch?v=_85m2uOQFOw
                                    I don't know where to get the correct firmware or program original remote to replacement controller, but it looks promising.
                                    The Winbond chips IC3301 and IC3701 are "SPI flash" chips, so the contents can probably be read by any USB or serial device programmer capable of communicating with the chip... I've recently ordered a CH341A USB programmer on eBay for about USD$5.00 but have not yet tried it.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4529
                                      • Italy - Milan
                                      #78
                                      Hi, i've followed on the Italian forum the case, the user managed to fix the tv with reflow of the bigger cpu on mainboard and another fix that i dont remember, tellme if you are interested..
                                      • Unspun01
                                        • Jun 2011
                                        • 349
                                        Hi Davi.P: can you share a link? I would very much like to know what problem they have and what they are doing to repair it.
                                        I didn't reflow anything but i did try heating the larger chips with hair dryer to see if it was bad solder connections but there was no change (still white screen with cyan/yellow artifacts)
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4529
                                          • Italy - Milan
                                          #80
                                          The link is this:
                                          https://www.plcforum.it/f/topic/2342...5f9000/?page=2
                                          but the user Tokit dont tell the right part about ic3113, the tps25xxx
                                          is not a programmable chip. Please if you fix your tv dont disappearr an come here to describe what you've done.
                                            Samsung Galaxy Book3 Ultra NP960XFH-XA1BE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA1BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA1BE boardview and NP960XFH-XA1BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 07:12 AM
                                            Samsung Galaxy Book3 Ultra NP960XFH-XA3BE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA3BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA3BE boardview and NP960XFH-XA3BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 06:40 AM
                                            Samsung Galaxy Book3 Ultra NP960XFH-XA2FR Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA2FR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA2FR boardview and NP960XFH-XA2FR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            Samsung Galaxy Book3 Ultra NP960XFH-XA1CA Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA1CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA1CA boardview and NP960XFH-XA1CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 06:38 AM
                                            Samsung Galaxy Book3 Ultra NP960XFH-XA3DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA3DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA3DE boardview and NP960XFH-XA3DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
