OMG SAMSUNG UN55F9000 Ultra HD, SMART, 3D 4K
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4498
    • Italy - Milan
    #101
    Re: OMG SAMSUNG UN55F9000 Ultra HD, SMART, 3D 4K
    reset have no sense, if your tv doesn't recognize the OC then there's something wrong at electrical level, i don't read again all the thread, i remeber there was more than one tension towards OC, check again, check also service manual for pinout..
    • Frank29578
      • Apr 2019
      • 30
      • Nederland
      #102
      okay yes normally the fan has to run in the one connect box and that doesn't happen either,let's see where I can find the service manuel
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4498
        • Italy - Milan
        #103
        i remember there was a pinout here in this thread, not?
        • Frank29578
          • Apr 2019
          • 30
          • Nederland
          #104
          no I have searched but no pinout
          and I can't find the service manuel anywhere. so that becomes puzzling
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4498
            • Italy - Milan
            #105
            i saw there is a 3,3v , 5v, 13v to the OC.
            • Frank29578
              • Apr 2019
              • 30
              • Nederland
              #106
              thank you i just tested. and all voltages are present. so weird that it doesn't work
              I have 3.3v 5.3v 5.3-v 12.4v
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4498
                • Italy - Milan
                #107
                The cable for the OC is the same as whose you used for the hu7500?
                • Frank29578
                  • Apr 2019
                  • 30
                  • Nederland
                  #108
                  yes i only have 1 cable. I tested it again on the HU7500 just works
                  • Frank29578
                    • Apr 2019
                    • 30
                    • Nederland
                    #109
                    maybe a Bad bga chip on the mainboard? that it does not receive a signal from the connect box??
                    I hope I find another mainboard because I'm tired of it
                    • jjanssen7
                      • Nov 2012
                      • 252
                      Those one connect boxes are not compatible f->JS etc. They are often model specific in my experience.
                      • Frank29578
                        • Apr 2019
                        • 30
                        • Nederland
                        #111
                        No, that is not true. you only have to adjust software or service menu otherwise it will restart every 20 seconds. just like the js9000 box do on the hu7500
                        the hardware of the js9000 box is the same as in the sek-3500u
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4498
                          • Italy - Milan
                          #112
                          I have a service manual but it's very poor of informations..
                          If you can't enter factory menu try sequence MENU 1 8 2 POWER, instead of INFO MENU MUTE POWER..
                          I think that your firmware could need to be upgraded to be compatible with the OC, i don't think OC has a firmware but you can try.
                          • Unspun01
                            • Jun 2011
                            • 349
                            The hardware may be the same, but like I said before, I think the OC box from JS version of TV needs to be reprogrammed to work in the "F" version of TV.
                            See post 23319 in the link that you yourself shared with the group:
                            https://www.avsforum.com/forum/166-l...n-kit-778.html
                            The poster called "Musician" states in post 23319:
                            Not to be a killjoy but before everyone in North America starts to do the happy dance and run out and buy a One Connect Box on eBay from a JS model in the hopes they can get it working on their HU or F series, please take note that the only sucess stories I have read so far have to do with JS OCB's manufactred for the European market and the box needs to match the set..."
                            I think that the One Connect box needs to be programmed with the correct firmware to work with your TV. Especially since you are mixing-and-matching a One Connect box that you purchased separately from the TV you are fixing.
                            I think since you reprogrammed IC3301 and you eliminated the white screen problem, I think your mainboard is fixed. I think you need to concentrate on programming the One Connect box with correct firmware.
                            • Frank29578
                              • Apr 2019
                              • 30
                              • Nederland
                              #114
                              I hope the mainboard is fixed
                              but that person Davideu also had an image before programming it. but fell out and gave the message this box is not suitable. so that's not the problem here i think...my f9000 doesn't even find the connectbox
                              and my js9000 box is from an ue55js9000 and the tv is also a ue. ue55F9000, I am from the Netherlands
                              • Frank29578
                                • Apr 2019
                                • 30
                                • Nederland
                                #115
                                I have never experienced that a js9000 box find no connection at all with another model of TV. I've seen them working on the hu series, s and F9000 more often. upside down image and always message that it is not suitable and switches off
                                as much as I hope my f9000 has been repaired. yet I do not believe that it is the one connect box
                                • Frank29578
                                  • Apr 2019
                                  • 30
                                  • Nederland
                                  #116
                                  thanks but menu 182 does not work / tv turns on when I press 1
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4498
                                    • Italy - Milan
                                    #117
                                    upgrade doesn't take place?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4498
                                      • Italy - Milan
                                      #118
                                      Check whether the data signals from OC connector on mainb. are connected to a little IC or by watching traces comes in a big chip, if it's a BGA then it needs reflow.. ops, before doing this the signals are LVDS so on mainb. side there are 100ohm balance resistors, check first the resistances, then check the voltages across them, if you have O-scope check the signals.
                                      • Frank29578
                                        • Apr 2019
                                        • 30
                                        • Nederland
                                        #119
                                        I can measure something but I don't have an oscilloscope
                                        • Frank29578
                                          • Apr 2019
                                          • 30
                                          • Nederland
                                          #120
                                          I don't know exactly what to measure. but if I measure between the connector that goes to the box and the conector on the mainboard that goes to the tcon, I also measure value, so it also seems good
                                            Samsung Galaxy Book3 Ultra NP960XFH-XA1BE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA1BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA1BE boardview and NP960XFH-XA1BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 07:12 AM
                                            Samsung Galaxy Book3 Ultra NP960XFH-XA3BE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA3BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA3BE boardview and NP960XFH-XA3BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 06:40 AM
                                            Samsung Galaxy Book3 Ultra NP960XFH-XA2FR Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA2FR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA2FR boardview and NP960XFH-XA2FR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            Samsung Galaxy Book3 Ultra Enterprise Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book3 Ultra Enterprise Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Enterprise boardview and Enterprise schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-07-2024, 06:38 AM
                                            Samsung Galaxy Book3 Ultra NP960XFH-XA2CA Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book3 Ultra NP960XFH-XA2CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP960XFH-XA2CA boardview and NP960XFH-XA2CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
