Philips 42PFL5332D/37 Chassis EJ3.0U LA Will Not Power On
  • dukie
    Junior Member
    • Feb 2017
    • 32
    After a thunderstorm in the area, My t.v. may have suffered an lighting strike? However, there's NO POWER.... Visual inspect power supply board but didn't find anything to catch my attention.
    How can i get a copy of an technical training manual or repair manual to troubleshoot the device thanks in advanced...
    Re: Philips 42PFL5332D/37 Chassis EJ3.0U LA Will Not Power On
    Try elektrotanya.com
    • dukie
      Junior Member
      • Feb 2017
      • 32
      Thanks for Info. I'll give it a try...
      • dukie
        Junior Member
        • Feb 2017
        • 32
        I Tried elektrotanya.com no repair manual for this model and chassis Number.
        Thanks again...
        • taity75
          • Jun 2017
          • Scotland
          hi I'm I'm looking for advice I no I should do my own post but I can't do one as I'm a newbie..
          my philips tv has 2 hdmi slots but none seem to be woring now, is there something I can do to maybe get them workjng again or ??
          • R_J
            • 9633
            Would this help?
            • dukie
              Junior Member
              • Feb 2017
              • 32
              Thank you, this will point me in the right direction!
              • dukie
                Junior Member
                • Feb 2017
                • 32
                provide more detail on the philips, such as: Model, chassis, etc.
                • dukie
                  Junior Member
                  • Feb 2017
                  • 32
                  Need Power Supply Schematics:
                  I hoping that someone on the forum will provide me a more detail repair manual, because the service manual i have on hand doesn't provide me with enough information to make a repair on the power supply.
                  Below is the service manual in reference to what i am reviewing. I hoping to troubleshoot for a fix.
                  Thanks Guys!
                  Power Supply Board:
                  PLCD300P1 / 3122 423 31812
                  Service Manual:
                  Philips Chassis EJ3.0ULA 26PFL5332D;32PFL5332D;37PFL5332D;42PFL5332D.pdf
                    I need good clear straight shot of the top and the bottom side of the power supply board, and also the pictures of the whole backside of the TV showing all the boards.
                    • dukie
                      Junior Member
                      • Feb 2017
                      • 32
                      here you go! hope there're okay for viewing...
                        Need the bottom side of the power supply board too to be able to trace out the circuits.
                          I found the board at shojimmy with top and bottom sides of the board:
                          Philips 312242724421 Power Supply Unit
                          http://www.shopjimmy.com/philips-312...pply-unit.htm#
                            So the main AC fuse is good for sure?
                            If it is then you need to measure the DCV between the two legs of the MAIN filter caps (there are four of them connected in parallel which are under the heatsink, it should have about 160VDC between the + & - legs). You have to take the board out and flip the board over to get to the cap's legs, I would plug the AC cord into GFCI outlet to protect yourself.
                            • dukie
                              Junior Member
                              • Feb 2017
                              • 32
                              i tried to get as close as possible without loosing image.
                                I found good pictures at shopjimmy, see post 13.
                                Read post 14 and reports the readings.
                                • dukie
                                  Junior Member
                                  • Feb 2017
                                  • 32
                                  thanks i'll give it shot!
                                  • R_J
                                    • 9633
                                    See if this is close
                                    • dukie
                                      Junior Member
                                      • Feb 2017
                                      • 32
                                      Thanks buddy, i've give a try...
                                      • dukie
                                        Junior Member
                                        • Feb 2017
                                        • 32
                                        i did measure the DCV between the two legs of the MAIN filter caps. there is 163.4VDC on each cap.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
                                        • CurtisC
                                          Philips 75pfl5704/F7 No sndby power
                                          by CurtisC
                                          Hello everyone. I'm brand new to the group. I'm trying to fix this Philips 4K TV. I have minimal experience with most of this so forgive me if I don't understand half of what is posted on these forums. I'm trying to find my way through it.
                                          Basically I got the TV from a previous owner who said it just died on them. So I wasn't there when it broke. It will not power on, no lights, no backlight, no sound.
                                          The output of the power supply has a 27 pin connection to the main board. Pins 18-27 (labeled P-On+20v) are the only pins reading power at 12v each. The pins marked ALL+3.3v, which...
                                          04-01-2023, 11:53 PM
