LF501EM6F Emerson 50" tv
  • dxhac69
    • Mar 2016
    • 34
    I have an LF501EM6F Emerson 50" tv with a main board model number BA4GU5G0201 4. I found two shorted caps on the back of the main board. C3825 and C3828.
    I am wondering if anyone has a board they can measure these caps on and let me know what they are? It might help someone else with one of these chirpers too. I measured 5.6uf on one I removed but it would be nice to have a little verification.
  • CapLeaker
    Leaking Member
    • 8196
    Re: LF501EM6F Emerson 50" tv
    If you measured a shorted cap, then you wound't read anything good in value. C3824 and C3827 are parallel to the ones you took out. So measure these.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Look like they are in parallel. If so they are probably same as other two
        What is the resistance reading between the two pads on the board where the caps?
        It will not be showing 5.6uF if you have shorted cap, you can easily verify that by shorting you cap tester leads together to simulate shorted cap measurement.
        • dxhac69
          • Mar 2016
          • 34
          No I pulled one of the others and then replaced it so it would not run away.
          • dxhac69
            • Mar 2016
            • 34
            I traced the line pulling and replacing components in the circuit until found the ones that were shorted to ground.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              So did you find the problem and which component was it?
              • dxhac69
                • Mar 2016
                • 34
                I replaced C3825 and C3828 with 5uf caps. Tv is functional. You're mileage may vary.
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
