Power suply doesn't work (DPS-214CP)
  • NoN4me
    • Jun 2017
    • 20
    • Spain
    I've got a TV wich power supply is a DPS-214CP (schematic attached), and the thing is that it doesn't power on. I dont even get stand by power.
    IC901 (DDA010) has an VCC Votage between 10 and 18 Volts in a triangle wave. It's said in the IC901 datasheet that IC starts up when vcc reachs 18 volts, but in my case Drain pin never starts switching.
    I have checked diodes resistors and caps but I can't find the problem.
    Can anybody lend a hand?
    Thank you in advance.
  • petehall347
    • Jan 2015
    • 4433
    • United Kingdom
    Re: Power suply doesn't work (DPS-214CP)
    is b+ good ?
    • CapLeaker
      Leaking Member
      • 8290
      maybe a dead pwm. Wouldn't be the first time...
      • NoN4me
        • Jun 2017
        • 20
        • Spain
        is b+ good ?
        Yes, 320 volts
        The pwm is that DDA010, isn't it? I have replaced it already. Nothing hapened.
        • dskall
          • Oct 2016
          • 2905
          • usa
          optocoupler, feedback voltage?
            What did you use for the GND ref. point for your meter or scope when you make the Voltage measurement in that primary side of the circuit?
            • NoN4me
              • Jun 2017
              • 20
              • Spain
              5 volts in FB pin
              I put the aligator clip of the scope in the negative pin of the main capacitor.
              • NoN4me
                • Jun 2017
                • 20
                • Spain
                Here you are the measures at the diferent points commented before.
                B+, FB pin, IC Vcc (in this order).
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  VCC is initially supplied via the DDA010 internal current cell until it reaches a specific value after which it switches off. The IC should then start to drive the internal mosfet to switch T901 which will then maintain VCC through the winding (pins 9-10) of T901 which is rectified and connected to VCC and it's charging capacitor C904.
                  If the IC fails to drive T901 for whatever reason, then there is no secondary voltage to maintain VCC. The IC restarts and charges the VCC startup capacitor via it's internal startup circuit once again until it reaches VCCstartup threshold at which point the internal charge circuit switches off.
                  This I believe would explain the ramp that you see on VCC
                  VCC = 18V and internal charge circuit switches off
                  VCC = 10.5V and internal charge circuit switches on
                  Can you scope the Drain (pin 5) and check that the internal mosfet is switching transformer T901
                  I would check R903, D902, C903, C904, D903, Q901, R904, ZD901
                  Out of curiosity are you using an isolation transformer to power up the set or using a scope isolation probe?
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    Here is spec sheet for DDA010 http://www.datasheetspdf.com/datasheet/DDA010.html
                    Seems 5v feedback is to high but I am not good with specs so budm or someone can correct. And educate.
                      The current sensing resistors on CS pin 3 are good?
                      If leave the scope on Drain pin 5 and nothing else hook up to the board then you apply AC to board, do you see any action at all on the Drain pin for seconds? The rectifier D950 in the cold side is good?
                      • NoN4me
                        • Jun 2017
                        • 20
                        • Spain
                        I have attached a screenshot of the drain pin.
                        Those components that you mentioned are OK.
                        About isolation I'm not using any of them, just being very careful avoiding touch the ground of the scope.
                        Yes, current sensing reistors are OK and D950 is also OK.
                        I have atached a screenshot of the input pin of the IC902 as well as a screenshot of the behaviour of the drain pin when I apply AC to board.
                        D950 is also OK.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          It's best practice to use an isolation transformer so that you don't accidentally give yourself a shock. Cheaper than a funeral.
                          • NoN4me
                            • Jun 2017
                            • 20
                            • Spain
                            Of course, I know, but I don't have an isolation transformer, I don't usually measure live areas.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              So transformer T901 is not being switched.
                              IC902 (IN1) needs 1.8V peak or more and the output (FPO) I think would be around 7V
                              • NoN4me
                                • Jun 2017
                                • 20
                                • Spain
                                Well, I have to say thay in this case when I measure FPO with the scope I obtain a flat line in 0 volts but when I measure with a multimeter I obtain 5 volts. (I desoldered FPO pin to measure it)
                                • PeteS in CA
                                  • Aug 2005
                                  • 3581
                                  • USA, Unsure of Planet
                                  Does the FB pin voltage of ~4.5-5V shut down the DDA010?
                                  PeteS in CA
                                  • NoN4me
                                    • Jun 2017
                                    • 20
                                    • Spain
                                    I don't know.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      From the data sheet it looks like FPO is Low (0V) when IN1 is between 1.17v --> 1.28V
                                      When IN1 => 1.28V then FPO goes High.
                                      You cannot measure FPO with the pin disconnected since it's an an open Drain connection.
                                      Datasheet post#15
                                      • NoN4me
                                        • Jun 2017
                                        • 20
                                        • Spain
                                        Ok, that way, with the pin soldered I measure near 5 volts, same as I currently have at FB pin of DDA010.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
