Vizio gv47lfhdtv10a. No sound after replacing fuse.
  • jshhh
    Help replacing fuse on my Mimaki CJV300-160 vinyl printer
    by jshhh
    Hi guys,
    I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
    How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
    Anybody know how to remove this type of fuse?
    (The fuse is toward the bottom of the image labeled F2)...
    06-17-2025, 01:35 AM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • corrize
    Replacing resistor fuse in Sony DV charger
    by corrize
    Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
    So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
    It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
    06-30-2025, 06:59 PM
  • ggil44
    Vizio M65-E0 No Picture, No Sound
    by ggil44
    Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
    09-03-2024, 08:30 PM
  • LEECH666
    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
    by LEECH666
    Good day ladies and gentleman!
    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
    01-19-2024, 05:46 PM
