Power Supply for Vizio sv471xvt Backlight Inverter Repair Help Pleasse!!
  • fharris1977
    • May 2017
    • 132
    Hello. I am repairing a Vizio sv471xvt and it had no standby led and wouldn't power on, so I ordered a used power supply and now the tv has standby and powers on but the screen is dark. I have to get a flashlight to see the menu on the screen, etc. Does anyone have any experience with this tv, to tell me what components need to be replaced to get the backlight working, because I'd hate to wait another two weeks returning this board and getting another one. I hate the backlight inverter is on the power supply with this model. Also, if anyone knows what components to replace on the original board to give it power and standby voltage I'd greatly appreciate that too.
    Re: Power Supply for Vizio sv471xvt Backlight Inverter Repair Help Pleasse!!
    We need good clear pictures of the whole backside of the TV showing how all the boards are connected together, then the picture of the whole power supply board, the pictures of the power supply connectors that goes to the main board, the pictures must be clear enough to read the pin labels.
    Did you do any DCV checking at all yet on the power supply connector that goes to the main board?
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
    • x_orange90_x
      Vizio E55-E1 bad backlights or bad inverter?
      by x_orange90_x
      I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
      I don't know how exactly to test the inverter itself. Is it...
      01-29-2025, 09:24 PM
      07-01-2024, 06:34 AM
    • lostone
      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
      by lostone
      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
      05-19-2024, 11:40 AM
