Proscan LED 32" TV not working.
  • THERED117
    • May 2017
    • 25
    Re: Proscan LED 32" TV not working.
    On the output of the PS the only pin with any voltage is pin(+5VSB) 5.01VDC
    My Spelling and Grammer Sucks.
    • Unspun01
      • Jun 2011
      • 349
      I have an RCA RLED3216A which is the same as the Proscan PLED3216A as described in this thread.
      My TV turns on ok, but locks up after about 10 seconds then shuts back off. I suspect a faulty EEPROM, but reading and reprogramming to a new EEPROM chip gives the same error... My eeprom must be corrupt.
      Does anyone have an EEPROM .BIN file from an RCA RLED3216A or Proscan PLED3216A that they can share?
      I note that with my EEPROM chip pulled, there is no standyby LED, so perhaps similar issue to the original poster?
      Any help is much appreciated.
      Thanks.
      • MMH3
        Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
        by MMH3
        i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
        Never ever i experienced problems with that.
        Now i have one 5050sff machine, where this jumper isnt working at all.
        I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
        The history of the machine is that i used it in my office...
        03-23-2025, 09:28 PM
      • DynaxSC
        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
        by DynaxSC
        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
        The board is generally working now, all PCIe ports are working, Windows installs normally.
        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
        03-10-2025, 12:27 PM
      • obelix24
        Macbook Air 2020 (a2179) - touch id not working
        by obelix24
        Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
        I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
        02-09-2025, 12:57 PM
      • hopkok
        Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
        by hopkok
        Hi masters, I need your help.
        I am working on Lenovo Legion 16ITHg6
        Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
        INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
        My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
        AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
        Power LED is not working as well, power button working well.
        UI26 ??? is there any firmware too? Powered by +3VALW_AG.
        Motherboard...
        05-04-2025, 09:35 AM
      • bociub
        laptop freezes, usb 2.0 not working, usb 3.0 working
        by bociub
        Hi there,
        It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
        Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
        08-25-2024, 03:44 PM
