Expertise needed 2 diagnose issue w horizontal lines
+ More Options
Posts
  • danigirl
    • May 2017
    SOS...!
    Hoping some1 can spare some expertise on this problem... I have a LG 55LW6500-TA and was watching TV last week. All of a sudden the picture turned into pink thin moving horizontal lines across the entire screen. (Unless there's an external reset button I'm not aware of ) I'm unable to reset the tv as I can't see the menu. On the weekend I took the back off and had a look at the boards - couldn't see anything 'burnt' or any domed capacitors.There was what appeared to look like a 'clot' on one of the ribbons leading from the T-con board to the panel (bottom of the Tv) so I softly rubbed it before turning the tv back on. It now starts with the pink lines for a few seconds but then changes to green / white flickering lines on a black background. As it warms up it tries to display a picture but doesn't quite get there so ends up looking like white flickering abstract images on the screen. I read a comment indicating that horizontal lines usually indicates a bad panel however was holding onto hope given the panel responded to this last action. Any suggestions to pinpoint the issue would be greatly appreciated. The tv's around 4.5-5 yrs old but I've only had it for 6 months and can't afford a replacement. I have recorded it if that'll help. Apologies for the length of this post & thank you in advance!
    2
    Motherboard
    0%
    0
    Panel
    0%
    2
    T-con board (don't think so though)
    0%
    0
    Power board
    0%
    0
    Capacitor
    0%
    0
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Expertise needed 2 diagnose issue w horizontal lines
    A photo may prove useful in helping to diagnose.
    • mannuoye
      • Dec 2017
      • 9
      Hello Everyone,
      I have a LG 55LW6500 TV and it stopped working suddenly. I had it connected to a computer via HDMI and I was watching a video on YouTube. All of a sudden TV turned off and then it came back on (just the front LED indicator light) but no picture, no sound and no backlights.
      So far, I have checked the power supply voltages and they are correct. I checked the LED backlights by jumping the connectors on power supply board and they are good. Now I think the main board is faulty. Unfortunately LG is not making EBT61555001 main board anymore and I am unable to find it anywhere (not even used one).
      Is there any other main board which I can use to get this TV running again?
      All I want is TV to turn on and connect my computer via HDMI.
      • SLK001
        • May 2014
        • 264
        If there is no replacement available, you'll have to troubleshoot the MB to the component level.
          If you can force the backlights on by isolating the BL-ON wire going back to the main board first and have all other cables back in place and able to get the backlights on but still no images on the screen; that means you have more than just bad BL-ON problem, as indicated, you will need the schematic to troubleshoot down to the component level to find the cause of the problem.
          • Ihandyrepair
            Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
            by Ihandyrepair
            Hi guys
            I just started fixing 4k TV few months ago. so I am still learning a lot
            I got this tv from friend complaint is ghosting or horizontal lines on image.
            never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
            then it started to show the ghosting white image.
            I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
            it has 3 thin small boards at the bottom of the...
            12-05-2022, 04:18 PM
          • ggil44
            Sony XBR-65X750D Horizontal lines bottom of screen
            by ggil44
            Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
            05-30-2023, 07:51 PM
          • noisykid
            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
            by noisykid
            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
            12-30-2024, 07:15 PM
          • x_orange90_x
            Samsung UN46C8000XFXZA Horizontal lines
            by x_orange90_x
            I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
            I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
            07-15-2023, 05:06 AM
          • Rubenlily
            Samsung QE50Q67TAU - horizontal lines
            by Rubenlily
            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
            I'm no expert but I've done the tape...
            08-16-2023, 01:12 PM
