Sharp LC-52SB55U powers on for 10 seconds then powers off
    hi
    i was given a sharp lcd tv with cracked screen
    owner said tv worked fine prior to screen cracked
    i powered tv on and it powers on ok backlight on...and there is a picture through the cracked screen area and sound..and the osd works fine....but after about 10 seconds tv powers off and opc light flashes as well as power light
    all i would like to know is i want to verify the boards on the tv are good or bad
    can the cracked screen be causing the tv to shut down?...normally if a lcd tv has a cracked screen from my brief experience is tv will stay on and not shut off unless there are other faulty boards....but maybe in this case its a safety shutdown???
    any input?
    thnaks
    Re: Sharp LC-52SB55U powers on for 10 seconds then powers off
    Would probably have to look up fault code.
      understandable but can anyone tell me if a cracked screen would/could cause some tvs to power off after a few seconds?
      or should the tv stay on as long as all boards are good?
      thats all im asking
        i even disconnected the tcon cable to the crakced screen and tv did same thing..power on for a few seconds then shut off
