TCL 32A12H TV no backlight
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    My latest repair is this TCL 32A12LH TV, which looks like something that has been thrown together with various bits of off the shelf..... errr...stuff
    I have no back light - It's got 24V from the PSU board to the inverter therefore looks like the SMPS is running.
    There are two other wires from PSU to inverter one has 4.8V on it, the other 2.4V. Had a look on my scope. no logic signals or pwm on them but there does seem to be a considerable (excessive?) amount of ripple - see pic (this is the 2.4V on 1V/cm DC).
    Could anyone tell me what signal/voltage should I see on those 4.8v/2.4v lines to activate the inverter?
    Cheers
    Rich
    Follow me on YouTube
    Learn Electronics Repair
    Re: TCL 32A12H TV no backlight
    Did you remove the metal off the then inverter board to check the fuses and the caps yet.
    One signal is BL-ON, another one is for Dimming.
    BTW, is that SAMSUNG LCD panel?
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Got the metal off - the 7A fuse on 24V rail near the power connector is OK
      Can't spot any other fuses
      The two electrolytic caps are not happy bunnies!
      I first thought one of these had been replaced before at some time as they are very similar values but different makes, but the glue holding them to the PCB looks the same on both so i guess they are both original?
      I don't suppose anything special needed here? - they are just connected from the 24V rail to 0V in parallel
      No shorts around the four STU432S Fets, but then if there was I would have expected a blown fuse.
      A quick check shows the STU432S are connected in pairs in some sort of parallel arrangement - The source of one pair going to 0V and the drain of the other pair going to 24V
      The driver chip is an OZ9966SN - I am struggling to find a proper datasheet for this, just this image http://www.datasheet4u.com/pdf/OZ9966SN-pdf/1093178 which at least gives some info.
      The screen is a samsung
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Those two electrolytics are in desperate need of changing and I'd do that straight away.
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          Unfortunately the only suitable replacements I had here were pulls off an old PSU or something. They looked OK on cap and esr meters. They were a bit too big to get the metal screen back on the inverter pcb but I guessed they would be OK for test purposes so I tacked them in place.
          Once I did that the 24V would come on for a few seconds then go off again. Sometimes I would hear a noise like a relay click just after power up.
          I was trying to get my scope on the two signal wires to see if it is trying to strike the inverter but the 24V was not staying present long enough. then after several attempts the 24V did come on for some seconds, and while I was looking at the signal lines one of the replacement caps popped quite spectacularly!
          I guess it wasn't as OK as I thought. Have got to go back to UK next week anyway so will order some new replacements as the bar this TV belongs to are not urgently needing it.
          There's nothing special about the original caps is there other than being small enough diameter to fit under the pcb sheild?
          NXH 35V 470uF SAM YOUNG (M)/105C
          Rubicon 35V 390uF ZLH T0918 105C PET
          Had a quick look at the electrolytics on the output side of the main SMPS and they all look OK visibly
            I would at least recap the caps for the 24V on the power supply board too at the same time.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              +1 That would be a wise move to do so at the same time.
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                I think that is excellent advice. Will do. Cheers.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Also bad cap on the mb I noticed
                    I just notice that too, it has black stuff on top and the top is domed.
                    • dicky96
                      Sun Seeker
                      • Mar 2017
                      • 1825
                      • Spain
                      I replaced the 470uF 35V cap on the inverter board again and also the domed 1000uF 16V cap that was spotted on the main board Interestingly that one read OK on my ESR meter but only 100uF on my cap meter.
                      Anyway with the three caps replaced the TV now powers up.
                      Cheers guys
                      • triplefour
                        by triplefour
                        09-13-2023, 10:43 PM
                      • DanPoka
                        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                        by DanPoka
                        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                        02-15-2025, 05:05 AM
                      • Comp_Pro
                        No Backlight Macbook A1990 820-01041
                        by Comp_Pro
                        Hello all,
                        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                        Tests performed:
                        There is no backlight even with a good screen.
                        Backlight IC is receiving the correct support voltages.
                        Fuse F8400 ok
                        Current sense resistor R8400 ok
                        Backlight IC is receiving 3.3V on enable pin.
                        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                        Backlight IC receiving 5V from PP5V_G3S
                        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                        05-06-2024, 10:23 PM
                      • jimbofz
                        lg 32LC46 backlight inverter board fault
                        by jimbofz
                        Hi this oldie had no backlight .after replacing caps on 24v rail ,
                        still no b/l this uses inverter type:1315 B1-16A,
                        im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                        all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                        this allows protect to be temporary overridden.
                        b/l now comes on
                        but the left hand side of pic is gradually darker than the right side
                        i have the cct for the tv
                        but it does not have inverter cct.
                        i opened it up to inspect the ccfl tubes
                        and they dont have any...
                        12-19-2021, 06:58 AM
                      • cheebster
                        iPad Pro 12.9 5th Gen Backlight Issue
                        by cheebster
                        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                        Anyone...
                        05-20-2025, 09:17 AM
