pn51d550c1fxzc no 5V stb
  • cheech3629
    • Sep 2016
    • 32
    this tv had no standby light on in front--took off the back and there was no stb voltage , but there is pson voltage.
    i went online to see what i could find and an hour later when i returned the tv was on and working perfectly. i could turn it off and back on with no issues.
    today i`m back to no stb voltage.
    there is 5 volts at the transistors on the back of the board but no voltage to the other two legs.there is also 5 volts in at the input pin of the IC at the back of the board----now i`m stuck.
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: pn51d550c1fxzc no 5V stb
    when you have no front led, do you have stby on pin2 of cn801 (pics are blury, so i hope that is right), and what does pin 1 of cn801 give you as you try to power the set up?
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
      "there was no stb voltage , but there is pson voltage."
      No way you can have PS-ON unless the main board is getting the STANDBY Voltage to run. Recheck your measurement.
      Pictures are too poor to read the pin labels.
      Also where are the Make and Model of this TV we are dealing with.
      • cheech3629
        • Sep 2016
        • 32
        samsung model is pn51d550c1fxzc
        cn801 at
        pin 1 = 2.944
        pin 2 =.004
        no change in anything when trying to power up.
        not sure if it matters but the only other place there is voltage is at
        J821 pin 5 = 2.944
        • dskall
          • Oct 2016
          • 2905
          • usa
          Well is seeing believing?
            Unplug the TV from the outlet, put black probe on the chassis and the red probe on STBY pin, plug the TV in and see if Voltage on STBY (A5V) pin jumps up for seconds or not, this is the main key point to check.
            BTW, if I remember correctly on this board, PS-ON has to go low to turn on the power supply.
            Looking at the bottom side of the board, this what I am seeing: There is a switched POWER MOFSET (QB810?) for the STBY (A5V), it will go into shutdown if there is over load on the output. The PS-ON is held high by ICQ802 (P/N???) which gets the 5V VCC from the 5V that is fed to QB810, so if QB 810 is shutdown you will still have Voltage on PS-ON, the PS-ON is pulled LOW by the main board if the main board is running.
            BN44-00444A, right?
            Pictures provided by shopjimmy
            • dskall
              • Oct 2016
              • 2905
              • usa
              So you are getting 5v just not to standby pin. Check under board at your 5v standby and see if you have bad connection at your connector. With your cable disconnected you probably still have 2.9v on ps_on
              • cheech3629
                • Sep 2016
                • 32
                When i plug the tv in there is no change in the STBY pin at all.
                QB810 5.3 V at the top but nothing at either of the bottom legs
                ICQ802 has 5.3 V at pin 1 but nowhere else
                I have another board--BN44-00330A that uses the same mosfet--in position QB810 as well. this one has 5.24 at the top , 5.25 on one leg and 9.86 at the other. The IC on this board is different.
                any ideas on what to test next ? i checked all the solder points for cracks or poor connections and did not see anything .
                • cheech3629
                  • Sep 2016
                  • 32
                  the problem board is BN44-00444A like you said.
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    Try running your trace back from the stby pin to where you pick up 5v
                    • cheech3629
                      • Sep 2016
                      • 32
                      QB810 supplies the 5V to the STBY pin.
                      I am not very good with the terms but if i understand this --
                      so the QB810 isnt receiving the voltage signal at the --gate ?
                      to allow the 5V to go to the drain ? which feeds the standby pin.
                      so i need to find out where the QB810 is supposed to get it`s signal from?
                        So you did leave the probes on the terminals as suggested? then next thing is to try it again but without the connectors on the power supply board except the power cord. I am trying to find out if the MOSFET was turned on for seconds or not, if not then the Gate drive is not working.
                        • cheech3629
                          • Sep 2016
                          • 32
                          Yes i tried it connected to the tv and then separately with just the powerboard on the bench. there is never a change on the stby pin.
                          • cheech3629
                            • Sep 2016
                            • 32
                            what is the gate drive ?
                              For the MOSFET to be on, the typical Gate Voltage will usually has to be about 3V or higher than the Voltage at Source pin to be ON, that the GATE drive Voltage. There is small SMD Transistor connected to GATE pin of that 5VSTBY MOSFET, may be the MOSFET itself is bad or that Gate drive transistor is bad, or that GATE drive transistor is not getting the ON command from that IC to turn it on.
                              The MOSFET can be bypass so you will have 5VSTBY all the time but you will no longer have the protection circuit (this is the second protection circuit beside the over current protection in the Primary drive circuit in the HOT side, you can try that and see if the TV will function properly when 5VSTBY is present or you may have more than one problem.
                              GATE drive:
                              https://cdn.badcaps-static.com/pdfs/...2d4372a282.pdf
                              • C152Heavy
                                by C152Heavy
                                Summary for TL-DR readers:
                                • VCC pin (18) of PFC...
                                01-11-2023, 02:53 PM
                              • Green Probe
                                Recapping a Denon AVR X6400h SMPS
                                by Green Probe
                                (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                                Disclaimer: I'm an amateur hobbyist and will get things wrong.
                                Always use caution when working around mains power and high voltage capacitors!
                                Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                                SYMPTOMS:
                                -No display...
                                07-18-2025, 03:36 PM
                                Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                by sam_sam_sam
                                This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                I am comparing them to a brand new one that I installed
                                The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                I going to let it run for several days before I remount back on the wall next to the...
                                09-05-2024, 06:48 PM
                              • Fernon@Repair
                                Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                by Fernon@Repair
                                i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                VCCIO voltage ok
                                VCCSA Voltage OK
                                VCCPLL Voltage OK
                                Ram Voltage ok
                                RamVTT OK
                                VPP 2.5 OK
                                But No Core Voltage
                                and i want to this vrm ic datasheet or pinout (ISL69269)
                                anyone have this ic pinout voltages?...
                                06-25-2025, 07:19 AM
