Picked up this tv that had no backlights, which after testing, determined to be a bad eeprom. I ordered a replacement from SJ and installed it. I now have a perfect picture.....except that it is upside down. I accessed the service menu but can't find an option to flip the image. Anyone know what setting it is? I've attached a pic of the service menu options.
RCA 46LB45RQ Inverted picture after eeprom replacement.
Tags: None
Re: RCA 46LB45RQ Inverted picture after eeprom replacement.
is it set for correctly for panel id ? -
have you tried menus such as geometry ?
maybe look in all menus and see if anything shows up .Comment
What's under LVDS map?Willing to help but I'm no expert.Comment
What I should have said is if you select LVDS Map does it allow you then to select the correct panel type.Willing to help but I'm no expert.Comment
No. The options are default, 6 bit a, 6bit b, 8 bit a, etc. When I changed it to 8 bit the picture became distorted.Comment
Maybe contact shopjimmy see what they can suggest, they maybe unaware that there eeprom does not work with the lcd panel type used in your set.Comment
I did send them an email as well. Since it was the weekend and they were closed I wanted to see if anybody on here had any ideas in case they don't.Comment
Was a solution ever found for this problem? I have the same issue with an RCA LED46C45RQ. I replaced EEPROM with a preprogrammed device to correct a power up issue. That corrected the original problem, but image is flipped. I have all of the same menus as shown in this post but I cannot find anything about HV flip. I presently drive the TV with a PC that I use as a DVR. I have inverted the output of that unit so I can watch TV right-side up, but all of the TV generated service menus are upside down.Comment
Might be in service menu--general settings--mirror control, might get in service menu by pressing menu and keying in 1147.Comment
do a firmware update or install firmwareComment
Thanks for the input. I have been all through the service menu. Mine look just like the ones shown earlier in this thread. I can't find anything that will do it. I believe you are correct that a firmware update is the only way to go.Comment
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by RauniHello, this is my first post on this forum, and my first attempted to repair a TV.
My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
Read also that we should test what happens if we... -
by IerwinHello everyone,
I got a 58pus7805 that shows some weird behavior.
The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
I managed to install the latest official firmware by holding the control button while plugging... -
by GoldenmonkeyMy samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
- Loading...
