Nand flash question
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Nand flash question
    I have just seen this question asked on another forum so thought i would post it here too as we are seeing nand issues too so whats you thoughts regarding this.
    I figured out many LCDs using Vestel-based boards with "only blinking LEDs" have worn out NAND flash chips. If power supply is working well (no capacitor problem) NAND flash is main problem. I unsoldered NAND128W3A from Vestel 17MB70 which normally should have 16MB capacity but when reading it with a NAND programmer it shows nearly 5MB bad blocks! Some mainboards do have one big NAND, some do have two (one big and one small)...
    My question is: Has anybody tried to swap faulty NAND with a brand new (empty) flash and tried a firmware update via USB? Is that possible or is bootloader which starts USB update located in NAND, too so that using a new (empty) flash update cannot start? Because of it is TSOP48 package I do not want to try without need....
  • tn245
    • Oct 2013
    • 530
    Re: Nand flash question
    I put a brand new NAND chip on a 17MB95 board and installed firmware. It corrupted again in about 6 months.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      I wonder what causes them to corrupt? maybe power spikes going too the ic?
      • tn245
        • Oct 2013
        • 530
        Well someone had a suggestion about this here:
        https://www.badcaps.net/forum/showpo...94&postcount=9
        Haven't seen anything else to back that up though.
        • tn245
          • Oct 2013
          • 530
          Also, to answer your other question. On the ones I've worked on the bootloader was on a seperate SPI ic, so was possible to do update via usb with new NAND chip.
          • diif
            • Feb 2014
            • 6978
            • England
            Which NAND programmer do you use Vince ?
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              i see the adaptors for the ics on aliexpress really cheap i have the tl866 programmer already, the post i copied was from another forum so was wondering if possible to re programme new ones etc
              https://www.aliexpress.com/item/Free...999.262.yo6lai
              • dskall
                • Oct 2016
                • 2905
                • usa
                Atmels reason for data corruption is low voltage. http://elcodis.com/parts/5786535/AT9...html#datasheet
                • jellytot
                  • Mar 2015
                  • 42
                  • Ireland
                  Hi Vinceroger69..I don't think the tl866 miniprog can program nand flash memory, You would need something like an Rt809f with the Peb1 addon module, but it would probably be better to get the newer Rt809H. Its around $120 from china but it does more e.g. Ec io chips on laptops..
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    I will have a read in the user manual etc before i buy the adaptor for it.
                    • Deeloc
                      How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
                      by Deeloc
                      I have a 1tb WALRAM SSD (Photo)
                      Controller SM2259XT2G (photo)
                      Samsung memory (photo):
                      Part Number K9DVGB8J1B DCK0
                      Name V-NAND V6
                      Type TLC
                      The SSD itself is detected as 1gb, but is not initialized.
                      There is a Sata to USB adapter
                      A lot of SMI MPTool, did not flash it. compare flash fail (17)
                      K9DVGB8J1B is not listed anywhere
                      What to flash?​...
                      06-05-2024, 08:32 AM
                    • DoOm86
                      Swap nand flash smartphone for data recovery
                      by DoOm86
                      Hello everyone.
                      I would like to know more about the following topic:
                      Nand flash on smartphone for data recovery.
                      I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
                      But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
                      How does it works? How do I know if data are encrypted or where is the key?
                      I know there are also very expensive external socket where you can put the nand flash in...
                      08-20-2023, 07:10 AM
                    • kara
                      Asus GX501v keyboard not working - keyboard firmware - solved!
                      by kara
                      Hello, i had a problem with this laptop keyboard. not working even after replacing with new original palmrest.
                      Solution after hours of researching is using a small software found on asus forum !
                      https://rog-forum.asus.com/t5/rog-ga.../701169/page/6
                      Thank you Bogdan Ciulei
                      Finally some good news :
                      I have managed to fix the problem.
                      First,
                      I am not responsible for any damage you might do to your hardware !
                      YOU DO THIS AT YOUR OWN RISK ! I ONLY PROVIDE POINTERS , DO
                      12-09-2025, 02:27 AM
                    • corrize
                      Nikon D800 camera - flash don’t work and capacitor don’t charge
                      by corrize
                      Hello, I'm stuck in troubleshooting…
                      The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                      In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                      When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                      10-01-2022, 10:02 AM
                    • tranquility
                      Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                      by tranquility
                      i want to repair an Onkyo TX-NR809 receiver.
                      symptoms:
                      on power on, display appears and i hear one click. enue functions is given.
                      - no hdmi output
                      - audio output not tested, but i think it is not there
                      - usb sticks are not recognized
                      if i read out the chips with display+standby button + tone+
                      both dts show only ????
                      chip is D830K013BZKB4
                      things i have done:
                      - reflow of the dts chip without taking off and reballing
                      - changed the aluminium caps without the big one with 25v because i dont...
                      08-25-2025, 01:04 AM
