IQ SMART TV 22" weird problem
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    Hello all,
    I have a very strange problem with a TV. It works fine for several days and one day without any notification it just doesnt turn on. It shows a red light which is standby light and it doesnt turn on. I hear a strang wisssssss sound from the board.
    If I unplug it from power and leave it several hours some times it works again and some times it shutdown even the red standby light.
    I am attaching an image of the board
  • jazzie366
    • May 2016
    • 304
    Re: IQ SMART TV 22" weird problem
    Originally posted by rippergr
    Hello all,
    Well, I see a CapXon GF series in the top. That's a series known for failing when being run hard. If it's being run within spec it should be fine, however I'd consider it suspect due to the fact I've seen it fail in Dell PSUs.
    Also, check caps on other boards as well, doesn't always have to be the power board that's the problem.
    Could you upload pics of the other boards as well please?
    Also, the cap above the two brown ones on the right side of the picture, what brand is that? The printing on it looks extremely low quality, could be a crap cap.
    One more thing, please upload some pictures of under the heatsinks on the board, would love to see what's under. Could be a cap hidden under one of those that's bulged.
    Also, be careful of the high voltage caps, that shit is no joke.
    Popcorn.
    • rippergr
      • May 2014
      • 345
      • Ελλάδα
      The other board seems ok, I hear the weird sound from the power board and louder near the power cable which comes from power outlet.
      I attach the other side board and the second board. I also attached the capacitor above two browns. I dont know how it is called.
      Also in the rear view of the board I marked the components that I have changed so far.
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        Hello all,
        the white plug con1 looks wonky to me
        • rippergr
          • May 2014
          • 345
          • Ελλάδα
          The back of the TV just pulls down the plug. It's quite sturdy.
          • rippergr
            • May 2014
            • 345
            • Ελλάδα
            Can you tell me what is that yellow box component above thermal fuse?
            The noise comes from there or from around there
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              safety capacitor by looks of it
              • dskall
                • Oct 2016
                • 2905
                • usa
                Might pull con1 and see if any arcing in connector or bad solder joints
                • rippergr
                  • May 2014
                  • 345
                  • Ελλάδα
                  That was a good idea. I removed the con1 and solder a cable directly on board but still the same noise and cannot power on the TV altough it has the standby led when I push the on button nothing happens or just shut down the led.
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    I would carefully inspect board for bad connections. Heat or cool board to see if it will turn on.
                    • rippergr
                      • May 2014
                      • 345
                      • Ελλάδα
                      I resolder most of the components . I cool the board and I heat it but it still does the same.
                      Is there any change that it's problem from the thermal fuse (I changed it because it was burned) or the yellow square capacitor?
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        Need good clear straight on pictures of back of tv with cover off and each board.
                        Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
                        Format:
                        Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
                        1 - XXXXXXX - XXv - XXXv
                        2 - XXXXXXX - XXXv - XXXv
                        3 - XXXXXXX - XXXv - XXXv
                        4 - etc.
                        • rippergr
                          • May 2014
                          • 345
                          • Ελλάδα
                          Ok the pins are
                          Descr. Standby Volt Power On Voltage
                          1)+12V 12.05 12.05
                          2)+12V 12.05 12.05
                          3)on/off 0.03 0.03
                          4)ADJ 5.03 5.03
                          5)GND
                          6)GND
                          I hope the pictures are clear
                          • rippergr
                            • May 2014
                            • 345
                            • Ελλάδα
                            Anyone has any idea what to look/change?
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              With the main board disconnected what voltages do you have on pins 1-6 when you switch on?
                              • rippergr
                                • May 2014
                                • 345
                                • Ελλάδα
                                If I unplug the logic board I cannot power on the TV, it has no lights.
                                The voltages on the pins are on 12V rails 12.05V and in all other 0V
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  Your not getting any change on on/off pin? Need to check voltages on main at regulators
                                  • rippergr
                                    • May 2014
                                    • 345
                                    • Ελλάδα
                                    What do you mean regulators? you mean transistors?
                                    • attainteddragon
                                      • Apr 2013
                                      • 764
                                      • australia
                                      these are your voltage regulators.
                                      i cant make out what the output voltage should be from the pics.
                                      measure them from left to right. center pin is the same as the tab pin.
                                      list what is written on the top line of each ic.
                                      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                                      • rippergr
                                        • May 2014
                                        • 345
                                        • Ελλάδα
                                        all of them are 1117 B 33 632K
                                        and all of them have 0v on all pins except the top one which has 3.3V on midle pin and 5V on right pin and 0V on left pin
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • huj3r
                                          Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                                          by huj3r
                                          Hi there!
                                          I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                                          Photo of the situation after the black shadow dissipates:
                                          After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                                          I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                                          > This indicates HFR Communication error. [ HFR Communication...
                                          08-15-2023, 10:55 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
