led issues
  • gwp
    • Apr 2017
    • usa
    led issues
    I purchased an LG 50ln5100 several months ago and it worked great. Then about 5 weeks ago it went out. I discovered the leds burned out so I purchased new ones. Then about 2 weeks went by and they burned out. After further inspection, I realize that only the right side burned out. I also check my old ones and the same thing, only right side burned out. So 6 strips burned out that are connected to the power strip. All the left ones work fine. I can't find any info on this particular problem. Any help would be great before spend anymore money on this. This makes no sense to me.
    Thanks a million
  • redwire
    • Dec 2010
    • 3912
    Re: led issues
    It looks like these LG sets are a lemon and eat LED's.
    Have you upgraded the set's firmware? This site advises it for LG's:
    " If you are replacing LEDs in an LG TV, it is recommended that you install the latest TV software after installation to minimize the risk of repeat LED failure. On Smart TV models, please update software from the Setup menu. For non-Smart TV models, please visit www.LG.com/us/support/tvs for instructions regarding your model. "
    • gwp
      • Apr 2017
      • usa
      Re: led issues
      Thanks, I'll try that if I can figure out how, I gotta little Forrest Gump in me. It's just strange to me why only one side burns out.
      Thanks again
        Re: led issues
        You should also turn down the backlights (NOT Brightness) level to as low as possible firmware update or not.
        • gwp
          • Apr 2017
          • usa
          Re: led issues
          Thanks, I always do that. Still the one side burn out is strange. It's the side that connects to the power strip. One would think the whole strip would burn out or at a few on the left, they connect together
          • mikey5791
            by mikey5791
            Hi to all forum members,
            12-26-2024, 04:55 AM
          • grss1982
            PSU killing components?
            by grss1982
            Hi everyone! Been a while!
            So I have a CM MWE 750 Bronze - V2 PSU powering the following:
            Ryzen 5 3400G
            Gigabyte B450 Auorus Motherboard
            32GB DDR4-3600 (2x16)
            ASUS TUF 1660 TI 6GB DDR6
            1TB NVME
            This was purchased by a friend about 3 years ago for her kid and now it showing signs of instability. The PC had this problem of the screen becoming garbled after it was booted up and idling in Windows. It also sometimes gets a BSOD. So I did some stress test by starting with Prime 95 and noticed that the torture test just fails and stops immediately....
            01-17-2025, 04:12 AM
          • paparazzo79
            Alienware 17 R3 screen black and lines flicker
            by paparazzo79
            Hi guys.I purchased 3 weeks ago used Alienware 17 R3 laptop with 980M and 6820HK....I did some ligh gaming so far,laptop worked okay, no issues at all.
            I turned it on earlier this morning went to have breakfast and when I came to my room all I saw on laptop is this on pic,and had to power it off to get normal pic.
            What is the culprit/cause of this, something serious?
            I did sime gaming like 30 min to an hour no issues in games, temp of laptop and GPU is max 82°C....
            04-13-2024, 12:24 AM
          • coinwizx
            Burned out PSU Corsiar HX1200 and NZXT C850, connected to wrong Molex/Sata cable from EVGA.
            by coinwizx
            Anybody has experience repair PSU burned out due to connect to EVGA molex/sata cables. I know the cable is not compatible (i got them mixed up), but I though i can connect it and use a PSU tested to find out which is the wrong sata/molex cables. As soo as I pluged in the powered molex cable to the PSU tester, the power supply short out, and will not turn on anymore. After the incident, the PSUs (both HX1200 and C850) try to power on and shut itself off immediately. The ATX PSU tester survice the short circult, still working perfectly. Anybody know if it's an easy fix or know which parts...
            09-09-2025, 03:11 PM
          • SoulFreeze
            Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
            by SoulFreeze
            Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
            After repairing the above issue, I realized the following remaining problem,
            Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
            The computer recognizes headphones are connected and displays a popup in windows
            Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
            06-21-2025, 09:53 AM
