Tnpa5349ab
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Tnpa5349ab
    I have a tc-p42s30 with a butchered attempt at a repair of the SN board.
    The board is TNPA5349AB. You can see by the pictures, the damage this guy did.
    There are unused spots on the board. Can I relocate the fet to it, along with the resistor, and replace the rest of the melted/blown up parts, and expect good results?
    I will check the buffer ICs also before replacing the blown fets.
    First pic is the fuck up, second is how it should be.
  • heavymachines
    • Mar 2011
    • 1028
    Re: Tnpa5349ab
    Ouch , i checked around for that SN board and out of stock everywhere i know of. Perhaps fleabay i didn't check makes me cringe. But perhaps you can find a cheap broken one to repair would have to be easier to fix than that mess, shop jimmy does have kits for it.
    • tw2005
      • Oct 2011
      • 6458
      Re: Tnpa5349ab
      Should work but grab a manual and check schematics. Something tells me a cheap hot air gun and max heat. Some people have no F-ing idea and should stay away for their safety and others.
      You may have to treat that electrolytic as suspect too if enough heat has split the polyester and liquidfy the SC2. Hopefully you have a retired SC board somewhere to get that from.
      you'll have tp be thorough and check other part sare present and accounted for. Grab a SJ photo and compare.
      Thanks for an interesting scenario
      • syaoran123
        • Jun 2014
        • 178
        Re: Tnpa5349ab
        ALWAYS ask the seller if they have tampered with the boards before purchasing a faulty tv.
        • flocko
          • Nov 2012
          • 1121
          Re: Tnpa5349ab
          I do a TNPA5349 board exchange on eBay Uk. I send out a refurbished board, and then the buyer sends me there faulty board when they have fitted and are happy that my refurbished board is working (I did offer a repair service but you get buyers saying the repair did not work and I want my money back even after the board is tested and working when it is returned), I then give them a small refund if there board is repairable. I have been sent a few with a lot more self inflicted damage than the one you have in your photo, and have told the sender sorry unable to refund on this.But I do think as my friend TW says it is repairable but not for resale. Good luck
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            Re: Tnpa5349ab
            I got the tv today for $10 with the stand and remote. I moved the resistor over to the un-used pad next to the cooked one. I put 4 fdg4536 on the board, one on the new pad, and a dg302 that read short on pad to one leg. The tv is fixed. Thanks for the input guys, TV T
            • tw2005
              • Oct 2011
              • 6458
              Re: Tnpa5349ab
              what are you going to use when this fairchilds runout?
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                Re: Tnpa5349ab
                I dont know. I have been ordering them when I have extra cash. Got enough for about 50 more plasmas. If you find another replacement, please let me know.
                • Don_CC12
                  • Apr 2017
                  • 3
                  Re: Tnpa5349ab
                  I, too, have a TNPA5349AB in the shop that I’m scratching my head over (2011 model TC-P42ST30). The set had the (apparently) classic dead short across Vsus, with blown IGBTs at Q401-Q402 and Q421-422. I ordered a kit from ShopJimmy and replaced these four devices. Q441, D401, and D421 all appeared good under a diode test, and the gate resistors were also within tolerance, so the supplied replacements for these were not used.
                  Reinstalling the board (with the new screws) and applying power immediately took out the same components as before. No other parts appeared to be damaged.
                  Per the checks in the service manual and supplemental information, no shorts were found on any of the driver outputs. Neither the gate signals of Q401-Q402 nor Q421-422 are stuck “high.” With the IGBTs removed, a quick check with the ‘scope shows virtually identical waveforms at the input to IC501 and the gate connections of Q401-Q402. Similarly, virtually identical waveforms were observed at the input to IC521 and the gate connections of Q421-Q422. A normal waveform was also seen at the gate of Q441. So it looks like all the drive components are in good shape.
                  What could I be missing? Is it possible that one of the components I did not change is breaking down under applied voltage? Is there anything else we should check? I do lots of electronics, but TVs in general and particularly plasma TVs are well off the beaten track for us.
                  Thanks in advance.
                  • tvtimmy
                    • Mar 2015
                    • 1160
                    • usa
                    Re: Tnpa5349ab
                    Check Q600 and the two DG302's that are in red.
                    • Don_CC12
                      • Apr 2017
                      • 3
                      Re: Tnpa5349ab
                      Thanks much for the reply, tvtimmy. Q600 is not shorted, nor are the other two transistors you indicated. I'm beginning to wonder whether we got some of those lovely fake IGBTs; there seem to be an awful lot of people that have had trouble with that issue. And FGD4536s are hard to find...
                      • cmlewis89
                        LG 47LB5DF blown power supply board
                        by cmlewis89
                        Hi folks,
                        I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                        09-03-2024, 07:50 PM
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • odtech
                        Asus UX490U laptop blown (caps?) on power board.
                        by odtech
                        Greetings friends.
                        I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
                        I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
                        Any guidance...
                        08-06-2023, 10:29 AM
