LG smart tv 55UB8500-UA
  • pkasreymeas
    • Mar 2017
    Hello Everyone,
    I have an LG smart t.v. that has no picture and backlight. There's audio. I went on YouTube to search on how to fix it. I came across Shopjimmy. I went through troubleshooting it and found that it "may" be the inverter. I went onto the website and ordered a kit, which included the power board, t-con board, and inverter board. I replaced the inverter board...turned on the t.v., there was picture, but that didn't last long at all...back to black screen again. With all of the frustration brewing, I took the t.v apart once more and decided to replace the power board and t-con board...thinking "why not?" I put the back cover back on and plugged in the t.v., clicked the power button on the remote, it came on! Whoo-hoo! Victory was short-lived...I tried to make selections on the remote and check the menu; nothing works from the remote! Now my t.v. is just a fuzzy white screen that I can't change channels or go on Netflix. Oh, initially it started with black streaks on the screen and the streaks started multiplying; until it became a black screen. I'm so defeated. Please help...
  • heavymachines
    • Mar 2011
    • 1028
    Re: LG smart tv 55UB8500-UA
    Read this https://www.badcaps.net/forum/showthread.php?t=39740
    • dskall
      • Oct 2016
      • 2905
      • usa
      And some pictures of screen. So before you started changing parts you had everything but backlights. Image on screen with flashlight?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Hmmmm...Sounds like a bad LEDs to me. The LGs usually have those edge lit backlight screens....
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4456
          • Italy - Milan
          I judge this type of repair kit at least absurd, i thought smart people lived only in Italy but not... how can somone change 3 of 4 boards to fix a BL problem?? And maybe it lasts that there was only a fu**ing led blown (as usual) and the tcon is not right replacement and has destroyed the panel...
          PS: never heard smart tv with ccfl, so it hasnt an inveter..
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • thesame
            Audi Smart Key Touch Screen not working.
            by thesame
            Hy guys, i have this Audi smart key with a touch screen not working, the key has a 450 mA battery inside that looks ok on the multimeter, but when connecting the usb c on the board there is no power consumption, no current going to the board. Has anyone worked on these before?...
            05-14-2024, 06:58 AM
          • ipatch
            ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
            by ipatch
            i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
            08-24-2024, 02:36 PM
