LG 47LN5750 Service Menu
  • packrat79
    • Mar 2017
    • 17
    Just serviced one of these in my shop, replacing a bad LED backlight. To prevent repeat failures, I usually just update the firmware, but I discovered that the firmware was already up to date when the LED failed. So my next idea is to reduce the LED brightness via the service menu, as I did recently with an RCA. Does anyone know how to access the service menu on these LG smart TV's, with the "magic" remote?
    IMO, the LED backlights on modern sets run way too bright, more than the customer will ever need unless maybe the TV is outside in full sunlight. I think they're set that way to guarantee premature failure, and needless to say when I service a set I don't want the same thing failing again in a couple of weeks.
    Thanks for any advice.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: LG 47LN5750 Service Menu
    maybe the android app included in this thread will get you into service mode just be carfull with what settings you alter though
    https://www.badcaps.net/forum/showth...rvice+menu+app
    The service remotes are quite expensive
    http://www.ebay.co.uk/itm/LG-SERVICE...3D310782853287
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      I don't know if this will get you in.
      http://openlgtv.org.ru/wiki/index.ph..._modes_/_menus
      • packrat79
        • Mar 2017
        • 17
        Yeah I now realize the service menu is pretty hard to access. Turns out I don't really need it though, as the backlight brightness can be adjusted via the consumer picture menu. I dialed it back from 70 to 50, and will advise the customer to keep it as low as they can tolerate to prolong the life of the set.
          Also tell them not to put the TV pictures setting to VIVID mode (or what ever the setting is called in LG TV), that will put backlights level to 100%.
          Some TV will also have the setting to each input, I.E. in tuner mode you may be set to 80%, but when you go to other input, the setting may not follow unless if give you a choice for Global setting that the setting will stay the same no matter what input you are using.
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • Robby-Gr
            TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
            by Robby-Gr
            I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
            However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
            The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
            Additional issues:...
            09-27-2025, 12:02 AM
          • tusiime
            How to access Vizio m652i-b2 service menu
            by tusiime
            The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
            So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
            Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
            09-15-2023, 09:57 AM
          • intercepter
            JVC LT-32CA120 service menu
            by intercepter
            I have JVC LT-32CA120
            Board:Vestel 17MB171
            I need rotate screen.It is possible in service menu and how to enter service menu?
            Thanks.
            12-10-2024, 10:29 AM
          • alltvrepairs
            Jvc Lt-65VU3000 reduce backlight from service menu
            by alltvrepairs
            I have just replaced led set of this vestel tv due to age.
            I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
            Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
            Thanks again....
            09-20-2025, 05:03 AM
