Panasonic TC-P50S30 7 Blinks
  • punkzter
    • Oct 2014
    • 24
    So, I have a Panasonic TC-P50S30 that is doing the 7 red blinks.
    At first, I guess I misdiagnosed it as a power supply issue, and replaced that board, but the problem persisted.
    I disconnected the cables at C20 and SC20, the red blinks increased to 8, but the tv still did not turn on.
    I did the sd/sw isolation test, but there were still 7 blinks.
    I also tested the A board by removing the 3 ribbon cables from the board and disconnecting SC2, SC11, and P35. When I did this, there was a solid red light.
    I did test for a short at SC2, by testing for continuity between the two pins, and I did not get continuity. The resistance was over 1M, although it did drop slowly as I held my multimeter there.
    I am assuming that the issue is the SC board, but is there a way to tell for sure? What confuses me is that I don't get a short on the board....
    What is the next step?
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Panasonic TC-P50S30 7 Blinks
    On the sc board measure Q401,Q402 etc for shorts. Very common to blow up.
    Repair kit:
    https://www.shopjimmy.com/panasonic-...-tc-p50s30.htm
    Repair video:
    https://www.youtube.com/watch?v=UmJYQ7oEbKg
    Even better repair video:
    https://www.youtube.com/watch?v=uIyHr13b5w8
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • punkzter
      • Oct 2014
      • 24
      I found a repair service for the SC board on ebay and sent it off. It turns out that there were some issues with it, and a new one are on the way to my place. I'll post an update when it arrives. They also tested my buffer boards, which were fine.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
        After all of...
        07-13-2024, 08:14 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
      • Biruslapio
        Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
        by Biruslapio
        Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
        It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
        It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
        02-16-2021, 09:44 PM
