Fuzzy audio.
  • pjherbert
    • Mar 2017
    Fuzzy audio.
    I have a Toshiba Model 46XV648U LCD TV. It's 8 years old and for approx. the last 6 months the audio would sound fuzzy and have an ecko to it. The only way to correct it is to shut the tv off then turn it on again. I've seen complaints about this when I've Googled it or searched it on YouTube, but never seen any remedies for the problem. I'm hoping I can find the fix here. Thanks.
  • nuala
    • Aug 2013
    • 37
    Re: Fuzzy audio.
    I believe this is a software update problem. support.toshiba.com/support/modelHome?freeText=2805249.
    • pjherbert
      • Mar 2017
      Re: Fuzzy audio.
      Thanks for the info.
      • pjherbert
        • Mar 2017
        Re: Fuzzy audio.
        With help from a coworker who is a fan of forums I was able to get an update and sve it to a thumb drive. only problem was when I plugged it into the tv it gave me the following message: "The software upgrade was unsuccessful. Please see warranty section of Owner's manual for instructions on finding the nearest Authorized
        service Station or visit TACP's web site at www.toshiba.com/tacp. Please remove any media cards and press OK. Your TV system will reboot after which you may resume normal viewing."
        I welcome any suggestions anyone has.
        • heavymachines
          • Mar 2011
          • 1028
          Re: Fuzzy audio.
          You certain it is the right firmware for your model? is the thumb drive properly formatted? I believe most firmwares come with a txt file instructing how to properly format and load firmware. Also make sure your usb port is not clogged up with dust.
          • samson7point1@yahoo.com
            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
            by samson7point1@yahoo.com
            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
            The player processes the audio signal using two different reference frequencies. The "R"...
            04-30-2024, 11:22 AM
          • i_am_patch
            Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
            by i_am_patch
            Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
            04-30-2024, 08:20 PM
          • MOSSEP
            Monitor Audio RSW12 - Green light but no audio
            by MOSSEP
            Hi
            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
            I have already tried replacing all of the...
            01-26-2025, 08:18 AM
          • grimacelord
            MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
            by grimacelord
            I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
            12-11-2023, 11:13 AM
          • Piaskos
            Dell Vostro 5490 - no sound, no audio device
            by Piaskos
            Hi, i've got problem with Dell Vostro 5490.
            Board - Mantis CML 18788-1
            Windows says "no audio device detected". The other functions work properly.
            What i've done:
            1. I checked motherboard
            2. I changed audio codec (ALC3204)
            3. I reflashed bios with clear ME
            4. Audio is enable in bios
            5. Both speakers are good
            6. After installing the drivers from the Dell website, the devices visible in the manager:
            - Audio for intel displays
            - Intel Smart Sound Technology...
            01-30-2023, 02:58 AM
