Re: Panasonic 65" VT20 10 blink code
same model went for $50 in Melbourne.
Nvm found it.thanks. made a cheapish offerLeave a comment:
There's a nice 50" 2D V20 in Cannington. Should just need the SC board going by the description.Leave a comment:
Well I've got a couple more things I'm trying on that thing to fix it still before I scrap it.
I wasnt sure if anyone had replaced a failed IC on the A board to make it work or one of the other million parts on it.
If the go is to just buy an A board I'm happy to do that but I havent found an Australia version of it yet on ebay? Got any pointers for that otherwise?
You don't need exacty manual just any of the VT series would do.
http://www.mxmee.com.au/index.php?ro...acturer_id=335
I hate to say it but I think his pricing is extortion but this is what happens when parts are obsolete and this is stated as New, never used. You can of course check this n the service menu.
I've had boards from a New Zealand who also liked stating they were new and both had 1000's of hrs clocked.
I just posted on another 10 blink A-board thread as I was just wonderin what I'd come across and fixed.
Shorted or damaged SD card slot on the A board. Kids or even adults can stick foreign objects or inserting the wrong way may do the same.
I had one, 10 blinks, 3.3v shorted and was bent pins in that SD slot.
It's free to look so check it, you never never know what you find sometimes.
You can convert any TNPH0844 to suit this size TV so even lok for another 50VT20, smashed screen , whatever but they're fairly scarce to find these days.Last edited by tw2005; 03-13-2017, 03:18 AM.Leave a comment:
If the go is to just buy an A board I'm happy to do that but I havent found an Australia version of it yet on ebay? Got any pointers for that otherwise?Leave a comment:
Took a punt and tried switching the A board from my 50" VT20A.
It turned on and had a display!
Didnt leave it on for very long as I didnt want to kill the board just in case.
Now to repairing the A board from this 65".
If anyones done this before I'd love to know what was wrong with theirs!Leave a comment:
Good news, they're both TNPH0844 boards. For sure chuck your 50" A board in and confirm it's A board.
Then I can give some tips?
Or spend $250 for a used A boardLeave a comment:
I know a few tricks. I recently had a 54V20. Blown SC and then found the A board also defective. Board number was different to the 50" which I had 2 spare. Upon closer inspection I discovered the boards were effectively the same except for a ver small difference in assembly on a filter requiring a different PCB pattern.
I converted the 50" board into the 54', hey presto up and running.
So obviously your about to ditch the 50 and try and fix the 65. Nice upgrade, bloody huge TV if you can pull it off.Leave a comment:
OK. So I've tested the TV with the D5 and D3 connectors disconnected.
The tv starts up with a white screen.
I therefore assume that I have a bad A board.
So does anyone have any pointers on where to start on the A board in fixing this?Leave a comment:
I've managed to find a better flow chart for diagnosing this problem. I'll follow the correct procedure and report back. I dont want to waste anyone's time.Leave a comment:
Sorry if it feels like I'm being a pain asking for help with 2 tv's at once. (I have another thread with the arcing 50" VT20 tv.)
I was hoping that if I got the 65" going I could test frame on it to compare to the 50" I'm having problems with...
Also wondering can I test the a 50" VT20 A board in this 65" tv if the connectors line up? I realise that the ports probably wont line up with the back of the TV and its not meant to be a permanent swap. I just thought IF it could help diagnose a problem with the PSU or A board of this TV it might help me fix the problem.Leave a comment:
I've picked up a faulty 65" VT20 on the weekend.
The TV doesnt turn on and emits the 10 blink code when connected.
I've opened this TV up and had a look for anything obvious. There is nothing visually obvious to see.
On initial connection I after its first attempt at powering up I've noticed a noise coming from a section of the powersupply. It seems to be coming from one of the transformers. Its kind of a buzzing noise. I've measured standby voltage of 5v and confirmed that is coming through ok to the A board.
Using the switch on the A board you hear the relays kick in and the buzzing noise at the transformer changes to a higher pitch. I can confirm that the 15V is output on the pins on the PSU. I havent checked what happens to it when it gets to the A board as it is only visible on the meter for about 2-3 seconds.
The leds on the SS and SC boards come on while this happens and then gradually discharge when the startup attempt fails.
Another test I've tried was removing all PSU connections to boards other than the A board. I've taken off the D board connectors from the A board too. The same thing occurs at attempted power up and the same 10 blink code is displayed.
So from this I'd assume that the problem is either the A board or the PSU. The only reason I'd guess the PSU is the noises that it emits from the transformer or components near the transformer sound a bit suspect to me.
Any guidance from anyone on what to check?
I've attempted to record the sounds heard when using the power button on the A board to turn the TV off/on.
https://drive.google.com/open?id=0B-...zliMFgydmF1WmsTags: None
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... -
by tikuHello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...09-05-2021, 05:02 AM - Loading...
