Help with programming an EEPROM
  • flibby3655
    • Nov 2016
    • 37
    Re: Help with programming an EEPROM
    After the calibration procedure, it continues saying it needs calibrated. Am I doing something wrong, or is it the nature of the beast?
    • vinceroger69
      • Mar 2012
      • 6714
      try too link the three test points first then turn on the meter it should say calibrate then do all the steps i have had this issue but cant remember what solved it but no it shouldnt keep saying that message.
      if that does not work go through the menu settings to calibration and try it that way too.
      • flibby3655
        • Nov 2016
        • 37
        I really want to give a big thanks to vinceroger69 for the patience that was given while guiding me through this thread.
        So, I would like to pay it forward.
        If you fried your tester like I did I used the file attached. If you have the same tester. Fuses settings can be found in Post #8
        • vinceroger69
          • Mar 2012
          • 6714
          is the tester working ok now? has the calibration message now gone on start up?
          • flibby3655
            • Nov 2016
            • 37
            Working and calibrated. I had to use different files (attached above). Thanks again!
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              The main thing is its working i wasnt sure if the files that worked for my tester would work on yours as mine had a rotary encoder etc and i think yours was a push button type theres various firmware available which changes all the time due to people adding diffrent tests etc its just trying them too see what works well with your own tester as there are many diffrent types and versions available but they seem too do the job ok i mainly use mine for esr testing.
              • SidneyCanadas
                93C46 and 93C56 EEPROM
                by SidneyCanadas
                I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                06-14-2023, 01:16 PM
              • dmccul2698
                Pioneer DEX-P99rs "No EEProm " diagnostic code.
                by dmccul2698
                Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                1). Understand the schematic and check the connections between the EEProm and DSP
                2). Check the functionality of the EEProm
                I don't know if this is the unit's problem but it's a place to start.
                I have little to no electronic experience...
                04-08-2024, 05:32 PM
              • Instafixx
                Macbook Display EEPROM Programming
                by Instafixx
                Namaste!
                Recently while doing Macbook Display repairs - due to a mishap by the supplier, we found that certain Macbook LCDs are cross -compatible but have Brightness issues.
                Some are DIM after start-up and some stay at Max brightness with the brightness control being disabled.
                While speaking to my supplier they said that they can program the LCDs at the Factory so that the brightness issue was resolved.
                I was wondering if there were a way we could do the same? I came upon a video online as well. Here is the link >...
                01-18-2023, 10:36 AM
              • ducky29
                24C04 Eeprom programming?
                by ducky29
                Hello. I have to read a 24c04(404rp) eeprom msop8 package but currently don't have an adapter for it. I have read couple comments that claim that you can read by connecting only some pins of the eeprom, only serial data and serial clock. Has anyone tried this or is there any way how to read the data without desoldering the chip?
                02-03-2021, 03:02 PM
              • edgarmg15
                Damaged EEPROM on TV Vizio E320-A0
                by edgarmg15
                Hi everyone
                I´m trying to repair a TV Vizio E320-A0 that I found in the street
                The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
                The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
                So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
                11-19-2022, 03:46 PM
