Help with programming an EEPROM
    Re: Help with programming an EEPROM
    After the calibration procedure, it continues saying it needs calibrated. Am I doing something wrong, or is it the nature of the beast?
      try too link the three test points first then turn on the meter it should say calibrate then do all the steps i have had this issue but cant remember what solved it but no it shouldnt keep saying that message.
      if that does not work go through the menu settings to calibration and try it that way too.
        I really want to give a big thanks to vinceroger69 for the patience that was given while guiding me through this thread.
        So, I would like to pay it forward.
        If you fried your tester like I did I used the file attached. If you have the same tester. Fuses settings can be found in Post #8
          is the tester working ok now? has the calibration message now gone on start up?
            Working and calibrated. I had to use different files (attached above). Thanks again!
              The main thing is its working i wasnt sure if the files that worked for my tester would work on yours as mine had a rotary encoder etc and i think yours was a push button type theres various firmware available which changes all the time due to people adding diffrent tests etc its just trying them too see what works well with your own tester as there are many diffrent types and versions available but they seem too do the job ok i mainly use mine for esr testing.
