Hey guys. I've tried searching and haven't found it online anywhere. I looked in the EEPROM dump thread above and it's not there. Does anyone know where I can get the files to flash on an EEPROM for this board? No one sells the eeprom already flashed but I can flash it myself if I can get the files. I've picked up 4 of these tv's in the last 6 months that had a bad eeprom that I've had to just strip the parts and I'd like to start fixing them if I could. Thanks
					Looking for EEPROM software for LG EBU60935403 42LE5400-UC
	Tags: None
 Re: Looking for EEPROM software for LG EBU60935403 42LE5400-UC
 Can you do a firmware update
 http://www.lg.com/us/support-product/lg-42LE5400Willing to help but I'm no expert.
 No. The tv freezes on the lg logo.Comment
 Are you certain you cannot put it on a usb stick and let it autorun at startup as given in the procedure?Willing to help but I'm no expert.Comment
 dick_barton - I haven't tried on this set but I did try a previous set because I have done that very thing with sony's. I'll dig up my flash drive and try on this one.
 diif - Is the EEPROM pre-programmed? I have tried searching for a pre-programmed eeprom and have not found anything. Do you have a link for a pre-programmed eeprom?Comment
 I don't have a link at present, i'm not near my pc. It wasn't hard to find though. The Nand was described as being the fix for a freeze with the LG logo and was about $30 and the eeprom was under $3Last edited by diif; 03-12-2017, 01:50 AM.Comment
 Yes, I found them for other models at 30 but nothing for this model. There was also a guy selling them for a similar model on ebay but he is out of stock. Correct me if i am mistaken, I have to use one orogrammed for this tv, I can't just use any because of the different panels being used,Comment
			by ekozeko333Hi all,
 🧠 What I’ve Done So Far
 Flashed...-
							Channel: BIOS Requests ONLY!
			by corrizeHello, I'm stuck in troubleshooting…
 The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
 In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
 When I press the flash button, it's detected by the system, flash icon appear on LDC display....
			by spmetroilHello,
 I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
 The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
 I have a CH341A programmer and I already attempted the following steps:- Identified the correct chip (W25Q128, 3.3V SPI flash).
- Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
- Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
 08-19-2025, 09:23 AM
			by abajorHello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
 Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
 The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
 I think my best shot is to figure out a way to read the internal flash memory outside...
			by IhandyrepairHI guys
 I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
 here is the issue
 I have Sony and android logo. but then 4 led red flash lights front of the tv
 I have 3.3v ref. 12v reg then T con 12v when I press the power on button
 but then I get black screen and 4 red flash light at the front LED
 but I get 3 led flash on the LED driver board.
 I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
 so I tried...
- Loading...
