Need INVFT320A Inverter
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Need INVFT320A Inverter
    what does the picture on the tv look like after this conversion as the leds will not have diffuser lens fitted over them like on proper strips
    The LED strips I mentioned are actually LED backlight replacement strips. Perhaps then I'm not calling it by the correct name. These are Samsung replacements that I get off e-bay and they do come with the diffuser lens attached. I have done this procedure about five (5) times already. 2-32", 1-42", 1-46" and 1-55" with success. The picture shows like normal and I have had no callbacks since.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Originally posted by budm
      https://www.badcaps.net/forum/attach...1&d=1489211243
      As labeled on the board:
      IN-PW?(M) = Internal PWM dimming
      EX-PW?(M) = External PWM Dimming
      ON/OFF = BL-ON BACKLIGHTS ON/OFF
      These signal are from the main board.
      the Dimming control signal will one of the two but not both.
      Thank for this information budm.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        sorry it was me i was thinking the cheap leds you get on a roll of ebay ali express etc yes it makes sence using the correct strips even salvaged out of smashed screen sets would do the job i guess.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Yes...and the TV now uses less power.....of course you would have to disable the Inverter section.....may have to cut copper traces or remove links so there is no unnecessary power usage.
          • dkneyle
            • Dec 2013
            • 441
            OK, it's official, I'm a knob! Of course, replacement inverter didn't change anything because I have faulty tubes. Build one of those CFL testers (a cut down CFL globe) and it fires up off the inverter. Even the old inverter which I put back in.
            Do I scrap or what? 32 inch. Not much demand or interest. Think I might put it aside and if I get another defective 32 inch through with broken panel but good tubes I might do a surgery job on it. Can't justify the LED conversion unless I do it as a learning experience.
            Sorry to all whose time I wasted trying to fault find a working inverter.
            • learnmore
              Help choosing replacement transformer for Levoit 600S SMPS
              by learnmore
              Hello Community,
              I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
              Peace
              LM...
              11-04-2025, 09:35 AM
            • ohren
              Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
              by ohren
              Hello!
              I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
              Measured voltages with no load:
              After rectifier diodes
              12V: 6.17 V
              5V: 5.67 V
              Secondary transformer pins AC measurement (really don't know if this says anything)
              12V: 2-2.5 V
              5V: 1.04 V
              I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
              03-18-2023, 10:33 AM
            • madan1
              Troubleshooting Cramer RV power supply
              by madan1
              Good day.
              I'm currently on a vacation and a friend from the camp site asked me to check why his camper power supply does not charge the batteries when hooked to the mains.
              The PSU is cramer and from what I've found the same mainboard is used in both cbc-b7 and bcc-b7. The control module/interface panel is Cramer D-5750.
              So what I've found so far - the transformer seems to be working fine and the board has no visually damaged components. I tested most of the diodes and transistors with a multimeter (the only tool I got here) and they read fine.
              The two thyristors have been...
              07-12-2025, 11:44 AM
            • Mirenia
              Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
              by Mirenia
              I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
              I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
              In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
              The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
              03-30-2025, 06:47 AM
            • orcic
              MASTER TL240 and new mainboard LW36BKC01
              by orcic
              I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
              The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
              After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
              Now I have some doubts about how to connect the new mainboard to the old power supply.
              First of...
              05-12-2023, 08:10 AM
