Samsung BN44-00506A power board dead no standby
  • fantoms
    • May 2020
    • 5
    • BG
    Re: Samsung BN44-00506A power board dead no standby
    hello,
    I do not want to start new thread and I will continue writhing in this because I have a problem with BN44-00506A too.
    The T27B551 is starting and working well for about 30-60 minutes and after that it is starting to restart in cycle. I can see the samsung logo while restarting and that's all.
    I opened the TV and sow that under the NT801S there is a burned mark.
    I would like to replace NT8001S but not sure with what exactly. Please help.
    I am attaching board pictures.
    • diif
      • Feb 2014
      • 6978
      • England
      You have several dry joints, resolder them.
      • vinceroger69
        • Mar 2012
        • 6714
        like diif says atart by reflowing every joint on the power supply there are a few dry Joints visible (looks like a bad one on the bridge rectifer just to point out one.)
        I have just fixed a constantly re starting samsung by just refowing the entire power supply.
        • fantoms
          • May 2020
          • 5
          • BG
          OK. Thanks.
          I resolder the rectifier, transformers and other suspicion joints.
          What about NT8001S. I think it has a crack and prefer to change it.
          It gives me 25k at 20 oC. Is that correct?
          • lotas
            • Jan 2016
            • 4856
            • Russia
            This is already a high resistance, should be in Om. need to replace it.
            • fantoms
              • May 2020
              • 5
              • BG
              #26
              Just to clarify I spoke for NT801S not NT8001S
              My mistake.
              Could you give me a clue which part to use for replacement.
              EDIT: I found it: SCK-053
              • vinceroger69
                • Mar 2012
                • 6714
                #27
                the thermistor could possibly be a
                NTC 5D-15, 5 Ohms @25c, 15 mm Dia. 6A max steady current, 0.156 Ohms @max current @25c
                • Cooperr
                  Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                  by Cooperr
                  I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                  The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                  10-21-2025, 01:11 PM
                • k370
                  Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                  by k370
                  I have a NM-A321 board that is dead, with no power at all.
                  When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                  With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                  • +3VALW
                  • +5VAUX
                  • 1.2VSUS_PWRGD
                  • 3VALW_PGD
                  • 1.05VAUX_PWRGD
                  Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                  The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                  09-23-2024, 11:57 AM
                • Destroyer-Br
                  [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                  by Destroyer-Br
                  I'm working on an Acer Nitro 5 unit with the following specs:
                  • Motherboard: LA-J871P Rev: 1B
                  • Model: Acer AN515-55-59MT
                  • S/N: NHQ7JAL00403906A973400
                  • SNID: 03902728734
                  Initial Issue
                  The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                  After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                  04-17-2025, 08:18 PM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
