Hitachi 50HYT62U/Vestel Turd
  • synaesthesia
    • Jul 2015
    • 35
    Have picked up a 50" Hitachi/Vestel thingy recently with a screen that turns on grey then fades out to black. Backlight appears to be working and PSU is OK (had a spare, both with the same result).
    Looks like a firmware issue after a little googling around. Would anyone happen to have the firmware for it? The board is a 17MB95M with sticker 10090755 23193499
    Failing that, is there anything else I should be looking for on this?
    Cheers
  • finntricky
    • Jan 2014
    • 449
    • uk
    Re: Hitachi 50HYT62U/Vestel Turd
    i have just dumped the same tv, but it was PANASONIC/VESTEL, i had the same problem as you, all turns on ok, with back lights working, and it turns out i had a shorted screen tab, so check the fuse on the T-CON first, and if that ok, check the screen tabs for heat,
    • synaesthesia
      • Jul 2015
      • 35
      Cheers. Unfortunately now too late Managed to drop the bloody panel
      All is not lost though, the LED's were mostly good and I'll be using them as lights in my new mancave
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ahh man how you lot break so many panels not one by me yet
        • synaesthesia
          • Jul 2015
          • 35
          It's my first I usually work on my snooker table however I'm currently clearing out my shed, so my work area is significantly reduced. People call me intelligent, but I often doubt that when I'm resting a 50" panel on a small box and then go to pick it up by each end.
          What a plum! Lesson learned!
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Lol you wont do it again, Im a jammy bugger as sometimes I do get rough handed but not had one crack yet.. But I did have a 60" Samsung Plasma which was a customers repair job that cracked on me due to a panel short if you want to find out why I can link the video on the repair I did cry over that I tell you
            • sordids999
              • May 2013
              • 2161
              • uk
              no backlight showing voltages seem ok on psu
              backlight legend connection + 156 volts steady - connection 36 volts but fluctuating from 36 volts to 37 volts im suspecting bad LED
              any thoughts ?
              thanks
              • sordids999
                • May 2013
                • 2161
                • uk
                Update ** Bad led's **
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  Thanks for the update.
                  • Bazilwrc164
                    Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                    by Bazilwrc164
                    I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                    The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                    I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                    If anyone can provide:
                    • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                    • Or a compatible EEPROM dump
                    07-23-2025, 12:15 PM
                  • Jaime Morillo
                    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                    by Jaime Morillo
                    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                    The TV was stuck on the logo and I couldn't access the update menu.
                    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                    The image result was good, but the image is inverted.
                    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                    08-18-2025, 11:38 AM
                  • massimomax
                    Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                    by massimomax
                    Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                    spero che qualcuno può averlo per riprogrammare eprom. grazie
                    Post in English !!!
                    I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                    02-28-2025, 07:27 AM
                  • FlailingEngineer
                    Help with Bush Tv (Vestel 17mb95m Mainboard)
                    by FlailingEngineer
                    Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                    Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                    05-31-2023, 06:52 AM
                  • Askic
                    Hitachi (Vestel) TV is not turning on
                    by Askic
                    Hello guys,
                    I have 32 inch Hitachi TV with Vestel PSU board 17IPS71. Tv was working normally and I shut it down normally via remote control.
                    The next morning it couldn't turn ON neither with remote controller or via button on the logic board.
                    There is a red standby LED ON, so it is not dead totally.
                    I have examined the PSU board and I cannot find find any traces of blown components or bulged caps. Electrolytic caps are manufactured by Elite.
                    I also check diodes and big MOSFET (with cooler/heatsink). It seems OK.
                    Can you tell me based on...
                    01-11-2023, 12:34 PM
