samsung CRT security monitor wont power on model ssc-12
  • shelby5041
    • Feb 2009
    • 1504
    • united states of america usa
    #61
    Re: samsung CRT security monitor wont power on model ssc-12
    i connected the 12v to the camera board only...directly..nothibng else and i will remove the main fuse ...i didnt do it originally...
    like i said the schematics seem not to match my board..i do not see a lot of the components on my board that are on the schematics
    • shelby5041
      • Feb 2009
      • 1504
      #62
      i used a .5a power supply set at 7v=12.2v output...and it did seem to power on the indicator lights on front of monitor for cameras
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        #63
        As more current needed by the TV alters so will the voltage. Perhaps as a very quick test I may use the power supply but I would recommend that you get hold of a regulated 12V supply and avoid more problems.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          #64
          Please note my earlier comments
          The set itself is rated at 34 Watts so a regulated supply of 12V x 3Amp should be capable of running it although I suspect 12V x 4 Amps or more if the camera's also have their power supplied by the TV.
          • shelby5041
            • Feb 2009
            • 1504
            #65
            yes i saw that..i just wanted to test camera board for the heck of it....wasnt intending on doing anything else
            now i would like to somehow find out why only 2.5v to voltage to camera board and obviously throughout entire power board
            • shelby5041
              • Feb 2009
              • 1504
              #66
              here are some photos of bottom of monitor board
              • shelby5041
                • Feb 2009
                • 1504
                #67
                more photos...
                the board is all thru holes..so im thinking if directed i should be able to repair this monitor..i hope
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • Journey11
                  Samsung TV won't turn on ... keeps cycling the power relay on & off
                  by Journey11
                  Hi All,
                  First time posting here ... my name is Kevin but my friends call me Journey.
                  I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                  After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                  It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                  07-04-2024, 02:44 PM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
