How do you remove the ribbon cables from a T-con board?
  • neferkamichael
    • Jan 2017
    • 9
    This is an image of a T-con board that goes in a 70 inch Sharp LCD TV(LC-70LE632U). You can see 2 black and white connectors on the top of the board that a ribbon cable plugs into. How do I get the ribbon cables out of the connectors?
    On the left side of this image close to the bottom is a white connector that a ribbon cable with a black connector plugs into. I have already pulled the ribbon cable out of the black connector as I attempted to unplug it.
    I have a service manual but am unable to identify the part number for it. Any help would be greatly appreciated.
    neferkamichael
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: How do you remove the ribbon cables from a T-con board?
    Unfortunately no picture attached.
    • neferkamichael
      • Jan 2017
      • 9
      Dick, I can see the image when I open this thread so don't know what went wrong.
      • dskall
        • Oct 2016
        • 2905
        • usa
        On the ribbon side of the black piece with your fingernail lift the black strip will pop up and you can pull ribbon cable. Might have to lift ribbon cable a little to get it out.
        • neferkamichael
          • Jan 2017
          • 9
          Dskall thank you very much, I removed the ribbon cables from the top connectors on the top of the board with no problem. Now when I install the new board do the ribbon cables snap into place or do I have to lift that black piece to install them?
          Now, the connector on the bottom left is not exactly the same as the top. The connector on the ribbon cable plugs into the connector on the board, or at least that's the way it looks to me. As I mentioned above, I have already pulled the ribbon cable out of the connector. Looks like there might be tabs on both sides of the connector, not sure.
          neferkamichael
          • dskall
            • Oct 2016
            • 2905
            • usa
            Connector on left should have tabs on each side. Squeeze them as you pull cable. When you replace you should hear them click in. The ones on top slid in then you push black strip down to lock them.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Interesting, It still doesn't show up on my page.
              • Dumah Brazorf
                • Jun 2013
                • 179
                • Italy
                Me neither.
                Quoting his first post there's the link. The link refers to shopjimmy's and does not load with Access Denied error.
                • petehall347
                  • Jan 2015
                  • 4426
                  • United Kingdom
                  lets see if this fixes the image ..
                  • Toasty
                    • Jul 2007
                    • 4171
                    Here are the images from Shop Jimmy. Resized them, but they're still HUGE!
                    ALWAYS use the "Go Advanced" button, then "Manage Attachments" when using pictures in a thread. Don't link to a website or use a picture sharing service. They will lose the picture should the time expire on the sharing site, or the website changes their product links.
                    Uploaded pictures to the forums will be here many years from now should someone else need help.
                    Cheers!
                    T
                    veritas odium parit
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      +1 Agree entirely with your comments Toasty
                      • neferkamichael
                        • Jan 2017
                        • 9
                        Gentlemen thank you so much for the help. I E-mailed Shop Jimmy about the ribbon cable I need but they don't carry it and can't provide the part number for it. I have a service manual for the TV but cannot identify the part number, nor does it seem to show it either. If anyone knows where I might get one I would be most grateful.
                        neferkamichael
                        • petehall347
                          • Jan 2015
                          • 4426
                          • United Kingdom
                          why new cables ?
                          • neferkamichael
                            • Jan 2017
                            • 9
                            Peter, I might have ruined the cable that goes from the T-con board to the main board. As I was attempting to get it loose from the T-con board, I pulled the ribbon cable out of the connector. I'd rather buy a new cable than take a chance, so if anyone can help me find the part number I would be most grateful.
                            neferkamichael
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                            • Hakuu
                              by Hakuu
                              Hi There,
                              More Details
                              TV Model - LG OLED77G1PUA
                              07-12-2023, 02:37 PM
