LG 50pj350-UB Has Sound, But No Picture
  • dukie
    Junior Member
    • Feb 2017
    • 32
    My LG 50pj350-UB has sound but no picture, I have replaced both the Y and the Z Sustain board, still no picture...HELP!!!!
    P.S. before i replaced theses board i would turn tv on/off several times to get picture, eventually that failed. After searching the web i found that the y and z sustain was the cause. Thanks in advanced.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 50pj350-UB Has Sound, But No Picture
    Mainboard prolly, run the test patterns.
    • dukie
      Junior Member
      • Feb 2017
      • 32
      Please forgive me, but what is a mainboard prolly, run the test patterns?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Prolly = probably. If you do a search for "run test pattern" on this forum will give you more information.
        • dukie
          Junior Member
          • Feb 2017
          • 32
          Hey i give it a try...thanks
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            +1 please excuse my lack of drive for this forum any more DB.
            • dukie
              Junior Member
              • Feb 2017
              • 32
              no problem...i did do a search for running test pattern for my LG 50pj350-UB but, came up with no information.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                service manual attached have a read it should tell you how to run the patterns etc
                • dukie
                  Junior Member
                  • Feb 2017
                  • 32
                  happy to have joined this site. Thank Buddy.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    Most of the information you need is on this forum some times you have to try different search terms if that makes sence.
                    not sure what control board your set uses? but on some you can generate test patterns on the tv by connecting the 2 holes beside R51 and R52 on the control board. Make sure you disconnect the lvds cable.
                    • dukie
                      Junior Member
                      • Feb 2017
                      • 32
                      Update:
                      i was unable to generate a test pattern after proforming in steps in the training manual. does this mean that the power supply or the main board is bad?
                      P.S. no standby light after disconnecting the SMPS and LVDS cables, the relay does click when is plugged in. Thanks
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        just for future refrence for new users correct way too get test patterns
                        PANEL TEST: Disconnect P301,
                        Remove LVDS Cable. Short across
                        Auto Gen TPs to generate a test
                        pattern. When A/C power is applied
                        I havnt worked on many plasmas but im sure a more experienced member will advise soon in the meantime if theres a flow chart for faults try following that and see what board it suggests
                        • dukie
                          Junior Member
                          • Feb 2017
                          • 32
                          i did try theses steps, couldn't get test pattern to show up....
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            i wonder if a bad buffer board can cause this as you do have sound
                            • maxvalutech
                              • Dec 2014
                              • 804
                              • australia
                              There is a heap of information on checks to do on plasma sets posted recently. Measure all voltages Vs Va etc plus those at connectors and post your results.
                              • dukie
                                Junior Member
                                • Feb 2017
                                • 32
                                okay, we'll do....
                                • TR103
                                  by TR103
                                  - it keeps rebooting
                                  01-22-2025, 04:12 PM
                                • Mgiffune
                                  by Mgiffune
                                  06-09-2024, 10:28 AM
                                • Ierwin
                                  by Ierwin
                                  05-13-2025, 03:31 PM
                                • jchang
                                  Samsung UN70NU6900F no picture and no sound
                                  by jchang
                                  Hi all
                                  I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                  Symptom:
                                  No picture no sound.
                                  When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                  No sound at all.
                                  What I tried:
                                  1. I tried unplugging the left or right ribbon...
                                  01-09-2023, 06:28 PM
                                • ChaosLegionnaire
                                  by ChaosLegionnaire
                                  09-13-2022, 09:02 AM
