Re: Emerson LF401EM5 LED TV no power won't turn on
I looking for power supply board, BA4G25F0102 Electrical Diagram anyone can help me?
Please someone has a electrical diagram for Emerson LF401EM5 or service manual?Leave a comment:
Did you ever show which parts you replaced?I am unsure where the glass diode goes forgot the names of them sorry lol will come to me once i hit send.Leave a comment:
Fixed it.
Optocoupler was at fault.Leave a comment:
Hi
I'm trying to fix the same power supply board, p/n BA4G25F0102
The transformer was making loud sound and I identified the shorted zener diode on the +21 rail.
I replaced the zener diode and the new one died and shorted the same way.
Looks like the transformer is producing too much voltage.
What could be the reason for that?
I was not able to find the schematics of this particular board but it appears to be similar to the attached one (see page 39).
Any ideas?Attached FilesLeave a comment:
ceramic caps have no polarity, so you are good to put it back in any way you like.Leave a comment:
Polarity on tiny capcitor
So I ordered the whole mainboard from ShopJimmy because they were out of stock on the main board repair kits and I installed it in the Emerson and the PSU is still squealing. So what I then did, which I should have thought of before I tried a known good main board, I unplugged all connections to the PSU except the power cord and I still get the sound. Which means the fault is on the PSU.
When the set is plugged in but on standby the transformer makes a light whine sound, then when you turn it on and the PSU powers up the mainboard and backlight and the PSU gets a load on it then the loud squealing begins. But you can still tell the problem is on the PSU transformer when it's on standby because of the light whine the transfomer makes without a load on it. So it can't be a fault on the main board.
I'm gonna return the mainboard to ShopJimmy for a refund and I've ordered a PSU. This should be the last fix I hope. Still better way better than chucking the thing in the trash. I'm sure Mother Earth will thank me.
I think I should go ahead and put the tiny smd capcitor back on the mainboard that I took off at C3637. Unless someone thinks it's unnecessary. I can't see any indication of polarity on this tiny capacitor. Does anyone know if this type of SMD cap has polarity?
Well I finally recieved and installed the Schottky SB3100 diode in place of that general purpose rectifier and still have the screeching sound coming from the yellow transformer. The good news is, this is a common problem, the PSU it appears is actually working fine now after the ShopJimmy repair kit job + Schottky diode at D653, and the whole buzzing sound issue has already been discussed in depth on BadCaps here:
https://www.badcaps.net/forum/showth...F401EM5&page=2
It appears the problem is actually coming from a bad componenet on the main board that's making the yellow transformer on the PSU vibrate. Thanks be to the higher knowledge of other members here, they seem to have isolated the component. It seems to be a capcitor. An SMD cap 4.7uf at C3637 on the main board.
I think I can handle removing the old one and soldering on the new. Member Capwizard says he removed the cap and the TV worked great:
Good news for your 5 Emerson TVs and Mother Earth! .....Will cost you almost nothing to repair!
After I removed Amp IC and two down-converters IC3605 & IC3604. Mother board still has short. So, I cut two traces of PCB to isolate the problem. found the low resistance 8.4ohm was caused by..................A SMD cap 4.7uf C3637...................I put all the parts back, but omitting the C3637 cap. The Emerson TV works beautifully.
Emerson TV Buzzing-Won't turn on LF391EM4F
[Tech Tips] Simply remove the SMD cap C3637 4.7uf.
http://www.shopjimmy.com/emerson-a4g...r-lf401em5.htm
But hey, if the TV will work without that cap with not even replacing it then I'm good with that.
Update: I went ahead and removed the SMD cap at C3637 on the main board and I still got the screeching coming from the power supply. Since I have no capability to track down the problem I guess my best bet is to get the main board repair kit from ShopJimmy or just get the whole main board.Leave a comment:
The white bars are Cathode so you have it on correctly.Leave a comment:
Question: Do SMD's have polarity? This is one of the ShopJimmy SMD's I soldered on. (Please ignore the atrocious soldering beads. The one on the left looks like a dog pile).
If you see the lines on that SMD, I wasn't sure if that indicated polarity so any SMD's with lines on one end I just took a guess and turned it to the side on the printed board that the arrow is pointing to which looks the most like a line for match up with polarity.
BTW, any component that is installed on the heatsink, if it has insulation sheet such as MICA and insulator for the mounting screw, you need to make sure they are back in place or you will short out the new part.Leave a comment:
Schottky SB3A0 Equivalent is SB3100
Looking at the datasheet for the SB3100 here - http://www.futurlec.com/Diodes/SB360.shtml
..it looks like the equivalent of the SB3A0 here - https://store.comet.bg/download-file.php?id=1701
I found the SB3100 on Ebay here shipping from China - http://www.ebay.com/itm/20pcs-SB3100...8AAOSwT5tWL0U8
Now all I gotta do is wait a month and a half for it to ship from ChinaLeave a comment:
Edit: I just wanted to ask one other thing. The three lead component from ShopJimmy (is that a cathode diode or a FET?) is screwed to what looks like a heat sink. That should have some thermal paste between that and the heat sink I'm guessing. It had some white paste behind it on the old one. I figured it was thermal paste. I put a little bit of Arctic Silver between them on the new one.
Edit 2: I just found some good information on diode substitution here - Schottky Diode SubstitutionLast edited by Toddo; 03-13-2017, 06:02 AM.Leave a comment:
The diodes are not replacements for each other so that's your problem.
The SBxxx is a fast acting Schottky rectifying diode and the INxxx is a general purpose diode.Leave a comment:
Check the temp of the diode you replaced. I am not sure if that is a good replacement. May be what's making the noise.Leave a comment:
Can you indentify this noise the PSU is making after repair
So I got all the ShopJimmy parts on the PSU and an additional bad diode that didn't come with the ShopJimmy kit and miraculously the TV powered right up. Got a minor hitch though. The PSU is making this crazy sound haha. It sounds like it's coming from the yellow transformer on the pics above. Can anyone make out what could be causing this. The TV is powering up fine and the fuse isn't blowing. I know some of my soldering was rough but all the connections must be fine cause it's powering up.
There is one diode that I had to replace that did not come with the shop Jimmy kit that I ascertained was bad. I could not find an exact replacement for that diode which was a SB3A0 (data sheet) 3amp 100volt with a IFSM of 80 amps. I found a similar diode on ebay which was an 1N5401 (data sheet). The SB3A0 is 3amps 100volts with an IFSM of 80 amps. The 1N5401 is 3amps 100volts with an IFSM of 200amps.
I can show the location of each part I replaced. I made a video so you can hear the sound the PSU is making here: https://youtu.be/hDMcqKj_uOc
Should I just let that sound go and not worry about it? The sound is not as alarming loud as it sounds in the video as the cell phone is so close to the PSU when I took the video but you can deffinitely hear it. The TV is working.Last edited by Toddo; 03-12-2017, 09:59 PM.Leave a comment:
SB3A0: 100V ratingLeave a comment:
SB3A0: 100V ratingAttached FilesLeave a comment:
Can someone help my identify this diode:
It's got SB3A0 printed on one side which I found is a SCHOTTKY BARRIER RECTIFIER diode and then it's got the value of 65 printed on the other side. Does "65" mean 65 volts? I'm gonna replace both of these diodes since the ShopJimmy repair kit did not include them and the one still has continuity with a leg lifted and the other one is still suspect. I'm gonna have to order them from ebay and I wanna make sure I get the right one.
Edit: Looking at stuff on the net just now I think the 65 mean 65 degrees celcius. So then does the 3A in the SB3A0 mean 3 amps? So am I looking for a Schottky 3amp 65 degree C diode? What about the voltage rating?Last edited by Toddo; 03-06-2017, 02:10 PM.Leave a comment:
sorry i meant replacement power supply not mainboard.Leave a comment:
by KYBOSHPicked up a Tektronix type 422 oscilloscope locally for a few bucks last year.
It wouldnt power on at all so I stowed it away under my bench for later testing.
Today I remembered it was down there and pulled it out to see what was what.
I checked for continuity and everything checked out.
There was a burned smell and a resistor was replaced with a temporary replacement (see yellow box in picture).
The burned smell is very pungent/acidic and I am not familiar with these vintage electronics to know whether I am smelling the remains of the replaced resistor or...1 Photo -
by grimacelordHello. I am working on a circuit board that is part of a motorized HDTV lift. The circuit board belongs to the controller component that tells the motor to either raise or lower the HDTV height.
The controller started sparking when the 29V power supply was attached and the green light on the power supply would go out as soon as it was plugged into the controller board. This indicated a shorted component and I was able to identify which component it is that is causing the short. When I remove this component, the short is cleared.
The problem is finding a replacement component.... -
by Mustafa85Hi guys,
Any one has Emerson industrial PSU schematic, it has 3 electronics cards in one package please have a look at pics -
by jkucukovI'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show... -
by littlejohnHello I have a Emerson research clock radio model CKS3516C and the transformer went out on it ,the label on the clock radio says 120VAC 6 watt backup battery DC 3v CR2430. the numbers on the transformer ST3591C-13SEN which I can't find anywhere for it. Can anyone please tell me the AC output voltage. Thanks
- Loading...
